… then we should definitely ask about the color (e.g. black, blue, red, yellow, green, … others) … ![]()
My two others are 3S4 vacuum tube oscillator with A and B batteries, and a TS-430S into a Heath KW Kompact with DC supply.
EL
No need to poke fun guys!
I still hold my view that a home built MTR is different to a factory (whatever a factory is defined as) built unit.
But as Andy has clarified, he’s interested in ‘classes’ of radio.
I worked on an antenna swich issue longer than a week, until I found the pin diode problem. But what’s about the ATU. Please give me a link to this project.
I activated once with my IC-706MKIIG and a handfull of times with a MTR-2B, but the vast majoriry of my HF activations have been with FT-817ND, so my vote went for this last only.
Guru
My “other” is a K1.
So that would be “other Elecraft” then.
Andy,
I answered this literally - KX3 - but I have used others in the past. Should I have included the ft-817 and ft-857 that I used before acquiring the KX3 or even the VX-7 which I still use from time to time or the VX-3 I used for much of my first year?
Rod
Current use only is fine Rod. I’d be impressed if you were working HF on your VX7!
Hi Andy,
My “other” is SW-3B
73, Jarek
Yes, so would I - an inverse transverter, perhaps.
Rod
Tnx, a brilliant idea to upgrade the mchf.
A KX3 was my mainstay for many years, now more a base camping radio along with the PX3 panadaptor and amplifier.
One of KD1JV home made tribander kit radios 40/30/20 metres for lightweight overnight walking trips.
Now however a new KX2 which is a really tiny capable radio. Fitted with the Elecraft paddle which I really like.
73’s Wal VK2WP
I’M USING XIEGU G90 !! I’M VERY HAPPY 73 DE IZ1GDB
My review of the G90 is in this weeks ICQ Podcast - my opinions only but I do like the rig for the price.
My other is Xiegu G90.
Martin
My “Other” is a “Miss Mosquita” 40m 5W transceiver.
Icom 705 for fair weather (both HF & VHF), my old Icom 703 is used for HF activations when the weather is not ideal & I don’t want to risk getting an expensive Icom 705 destroyed in the rain!
If the weather is bad then I typically activate VHF only with the handheld radios from my “other” section:-
My handhelds are an Icom IC-E92D & a Yaesu VX-8E. Both of which are advertised as “submersible”. I’m not sure that I would want to test that theory by taking them underwater but I have no concerns about getting them very wet when the rain is blowing sideways!!!
I also have an old Yaesu FT-290 which I occasionally take out on SOTA trips…more for nostalgia than practicality as it is quite big & heavy compared to my other options. I also have a small linear amplifier which takes my FT-290 up to around 25 watts.
200 votes is better than I expected. I leave this open for a few more days.
I had expected that another poll on the “other” section would be needed and the numbers here confirm that. I’ll set that up in a few days with most of the radios mentioned so far.
