Throw yourself at the ground and miss. GM/ES-042
Don’t do anything stupid
– my wife before I leave the house
I don’t disagree but the problem with this statement is that it’s relative. What is perfectly sensible to me is utterly foolish to the next person.
I’ve been eyeing Hunt Hill, GM/ES-042, for a while, but wanted a relatively calm day, as judging from previous reports and the internet, there isn’t much shelter on the summit. It’s also on my list of summits I can do when I have to do both school drop off and pick up. I decided to take the normal (not stupid? - again, relative! :scientist:) route from Glen Esk.
I had my bike and would cycle to the footbridge over the Lee, then head straight up and across to the summit. For my return, I wanted to see the waterfalls and so walk down to the Falls of Damff and then follow the water and path back to the bike - easy!
It was glorious sunshine and blue skies in Aberdeen and all the way there…until about 3 miles from the car park, when the cloud or fog came in. I was optimistic that the summit would still be in the sun and this was just some valley mist.
The cycle is along a nice track and relatively flat the whole way. Whilst the scenary was stunning, you can still enjoy it on a bike and save a lot of time! I dumped the bike in the heather just before the footbridge. The ground before and after the bridge was sheet ice, so some careful maneuvering to get on and off the bridge was required!
From here it was straight up the hill as best as possible. There are occasional paths but these seem to run all over the place and not necessarily where I wanted to go.
It’s a balance of taking a longer route and going further away from the summit, but gentler gradient and trying to take a shortcut but end up facing more and more vertical sections. No surprises what route I tried.
Once on the top it’s an easier incline up to the summit, getting a little steeper as you near.
As I climbed higher the amount of snow increased, and in places it covered large sections of the hillside. It did mean the peat hags were filled in with snow and I could skip across them. Interestingly most of the snow was on the southern side of the hill.
As required under the obligations of climbing GM/ES, Fraser @MM0EFI, was looking for a complete, and so we were hopeful on 2m. He was working but that doesn’t usually stop him from nipping out for a quick QSO. I’d alerted for 11:30am and needed to be on time, so that Fraser could serve the real workers of Westhill their christmas dinner. I was ready by 11:30 but Fraser was busy, so I admired the view whilst eating my chicken roll.
Fraser let me know he was on his way, and I just put out a call and we managed to work whilst he was still in the car park! I did call further on 2m but all quiet. So I switch to HF. There was a slight breeze on the summit, and the air was cold, so I wasted some time wandering about seeing if there was a better spot that offered a bit of shelter. I decided there wasn’t and just got on with it. I setup for 40m, spotted and called CQ. It took a few goes calling CQ before anyone replied. Recently there are already several stations waiting after I do my first call. However, the chasers soon started and I had a nice steady stream, offering the chance for a quick chat beyond the usual RST and thanks. I think the surrounding beauty reflected in my voice as several commented on how cheerful I was. Or something like that.
10 minutes on the air and after the faffing about at the start, I was running short on time, and decided not to try chasing summits and pack up, and continue my route. This didn’t start well as I proceeded to march off in the completely wrong direction as I’d “seen the stream” and knew where to go. I had seen a stream but it was the Burn of Damff to the west, rather than the falls to the south. I wasn’t too far off and reoriented back the right way.
A classic cause of issues at work is “time pressure”, people making bad choices because they are or think they are short on time. That was me and the thought of school pick up in a few hours time.
I’m not stupid. I’ll take a shortcut.
I could see and hear the waterfalls below and without looking at any map decided I could join the path from here. Perhaps I should’ve taken advice from others before me…
It was tricky to take photos of the route to demonstrate just how silly it was, partially as I was using my hands to hold trees, clumps of grass or rock faces as I scrambled down the side.
There was one moment where I came to a dead end, and the only way to go was edge past a huge boulder on about 20 cm of grass above a 5-6m drop. Of course it wasn’t the only way, I could go back the way I came but you know…tick tock tick tock :watch::eyes:. In this moment the wise words of my wife came into my head, and I, too, thought “this is stupid”. :person_facepalming:
I pressed on and made it :sweat_smile:, and soon reached the path by the water. The small streams running off the hill top made some impressive icicles on the rock faces, and the waterfalls were impressive and loud!
Back to the bike through a very chilly gully. I met another hiker admiring the views at the footbridge and he shared some of his adventures over the years in the area.
The cycle back was speedy, it’s slightly downhill the whole way, and home with enough time for a cup of tea before the school bell rings!
Well done for fulfilling your contractual obligations. I think you need to up the game in 2025. I need to to get my last 32 / 88 ES completes so I can get on with my life.
This mission is yours should you choose to accept it.
Well those photos were a visual feast, thanks for the risks you took to take them.
Our wives have the benefit of being able to refer to our track record. unfortunately. :slightly_smiling_face:
You mean all the GM/CS…and then…
My camera never does it justice!
I used to blame my low cost camera, so bought a high cost one, the photos didn’t really improve in areas other than precise focus (lens should get the credit, not the camera itself). now I find myself admiring photos taken with phones and I look at my mirrorless Canon M5 but it just stares back at me with that one-eyed look it has, and I have no option but to go back to trying better composition, avoid back lighting, you know, the basics. But a phone costing AUD1500+ starts to be better value if you sell your camera to finance it. I like fiddling with the lenses though…like having a programmable memory keyer (bought a used CMOS-4 recently, ah the gadgetry this hobby forces you to buy…)
…thanks Alex, great report with terrific photos. Well done.
In my days before radio, I’d carry a DSLR then later a mirrorless camera with me. But I always struggled with landscapes. I like telephoto landscapes but usually just took photos of the people on the walk with me.
Now it’s an iPhone 13 that I’m carrying anyway. Snap a few shots, hit auto in the editor and jobs done :sweat_smile:
I’ve thought about a Ricoh GRIIIx to bring along as it’s small and has an APS-C sensor vs. the tiny thing in my phone but still seems unnecessary, and I’m not sure the photos would improve.
Excellent report Alex… another one that reminds me that I don’t really need to see the falls and I should be retracing my steps when I descend from the summit. Also it is good to be relieved of the duty incumbent upon all who activate in GM/ES to provide Fraser with a Complete. :wink:
You were certainly having a better day than down here in Middle England which was overcast and damp, but I was no doubt considerably more comfortable than you were during our QSO. Well done on activating another one in style. :grinning:
I think the sensible route would be to walk to the falls first, all the way to the footbridge at falls of Damff, then climb to the summit. Afterwards, go down the other side (where I climbed) but go beyond all the rocks and crags and walk around the hillside back to the foot bridge.
No shortcuts! :sweat_smile:
What a great winter landscape. I like the pictures of yours and watch your reports with interest.
Thanks for the reminder! :slight_smile:
73, Johannes
This kind of landscape is difficult to translate into a picture probably because it doesn’t have a central element, a particular subject. Hills are low and round and “endless”. It’s all about atmosphere and feeling and I believe the classic 50mm is the best at this exercise. Wide angle give flat picture. Telephoto, I’m not convinced since there is often no particular big detail (a summit , a cliff …) to zoom on.
Every time I didn’t take it I bit my fingers because it would have been great pictures. So I keep carrying my big full frame DSLR and half of the time I don’t even turn it on since the light is not good or there is just nothing picturable.
With phone photos, composition is everything. We have a particular issue in GM/ES in that many of the summits are rounded or flat topped. Shots taken from summits tend to push the views into the far distance. Sometimes it’s better to embrace this and ignore the view and take a different style of photo.
Beinn a’Bhuird summit plateau, with and without mountain background. I like both.
Plateaux on the Air?
Superb photos and a great account - well some of it. You have to remember that I’m a ‘wife’ as well as an activator so I read and understand (usually) what risks you are taking and really shouldn’t if you are taking the ‘wife’ into account. However I have the same problem at times but this is a ‘husband’ whispering in my ear… but my hearing is definitely getting much worse!!
As the quacks all say, when you reach my mature age, whatever you do you must stay upright as a fall is the most likely thing to bring your fun (and possibly your life) to a rapid close. Does anyone remember that classic picture back on 13 March of me with mud on my face and nose after an ascent of Mynydd Troed GW/SW-009? Moral it is safer to slip (if you must) on mud rather than ice or rock! :roll_eyes:
73 Viki
Another super report with photos to match. Thanks Alex - looks like I have to visit at some point.
So you think you’re about at the summit, but you find you’ve still got 3km to go. :joy:
