Activation planned for tomorrow morning. Start local time about 5:30. See sotawatch for updates.
I will use aprs for my location. www.Aprs.fi/JJ1FJK-7
Not sure if I have reception for APRS.
Plan is to use mainly 20m. And 40m if there is space for dipole.
2m FM and 70cm on JA call frequency.
Just looked at the SMS spots. Andy spotter added a /p that I did not send.
I would suggest to look at that again because I just added a /8 for Hokkaido.
That’s how it is done for Japan (and by the way also optionally in Austria instead of /P )
@MM0FMF Andy could you have a look at that please.
I send SMS as JJ1FJK/8 and got spotted as JJ1FJK/8/P.
Not correct at all but hopefully did not cause too much confusions for the chasers.
Thanks
Ah yes… you could just type in the SMS for now. It’s an annoying detail not being spotted perfectly, I know that quite often when activating outside the UK I end up being spotted as MM0FMF/P when I’m probably F/M0FMF/P. as I just use the short cut of ‘!’. The important bit is what goes out on the air.
The special characters used by Andy’s SMS gateways are accepted by SOTA Spotter. I haven’t tested them recently, but I haven’t received any bug reports either.
I will be up early and listen for you on 20m tomorrow morning! I currently have no antenna for 40m. The last storm took it down.
Good luck with the ascend and the WX!
I was waiting for your QRV on Tuesday but condition between JA8 and JA7 was not good and I could hardly hear your signal on 20m nor 40m.
Today I put up IV-DP on my work-office and waited for your QRV with my FT-818.
On 20m I heard JA4RQO but your signal was unfortunately unreadable.
So I went back home during my lunch time and at last I GOT YOU on 40m IYYEEESS!!
