Moel Gyw GW/NW-053
With the excellent weather this afternoon I couldn’t resist going on an evening activation i.e playing radio on a near by summit. After hearing plenty of good activation’s taking place this morning, I thought I would share a few images of the inversion layer which developed and collapsed over the duration and the awesome sun set over Snowdonia which ended the activation.
The walk up was fairly quick, compared to a year ago where I was taking my PicASTAR up along side seemed all too easy. I set up on the burial mound this time as its much flatter and it offered a slightly wider view of the surrounding hills. I didn’t see a soul today which for this hill I found rather odd seen as its popular with walkers.
First band to work was 40m as per usual to try and catch the last of the inter G opening before the skip lengthened. The newly constructed 40/17m 5/8L vertical was on its second activation and proving a much better antenna for setting up on “peaky” summits. A run with 20 or so stations finished 40m SSB, a few presses of the band select and connecting the matching stub into the tee-piece brought me onto 17m.
The antenna loads perfectly after much trimming on 17m, The band seemed active but not many stations where worked at this time which seemed odd. I switched to 15m using my dual band 1/4L Vert to catch some US chasers before the band closed, which proved to be successful bagging 12 or so NA chasers including a s2s with VE2DDZ who was a perfect copy on his KX3 <=> KX3 QSO. A few G stations including Phil G4OBK with a good signal made it into the log.
After 15m had faded out, I went back to 17m. The band had opened slightly more, but by this time the sun was setting so I opted to watch it instead for a while. With the headphones on listening to a NA station the band seemed to change instantaneously as the sun dropped. A South Africa station beaming NA was heard as well as Japan plus lots of other interesting DX. My 12W wasn’t going to cut through against the big stations in NA; so I worked what I could and managed a few West coast stations and a VE5 on 17 which was great.
This all makes such a change back from a couple of months ago, where a good run on 40m before the situation became unbearable on the summit which consequently ended the activation. Time to relax, sip the soup and take everything in that is good around you.
A great little hill - If your visiting Wales, Check out the Clwydian Range.
Jonathan - GW2HFR
You were a fine signal on 15 metres into Kenya at close to 9pm Kenya time. Shortly after I had to pack up as a huge thunderstorm came over. It dumped so much water on the house that it flooded in through a window, set off the alarm, and meant I had much mopping and drying to do…
73, Rick 5Z4/M0LEP
Nice report.
Stunning set set views. :open_mouth:
Thanks for the Sota contact yesterday evening :smiley:
Karl
Hi Jonathan,
Congrats on some great DX, it’s always good to get into the West coast of NA. However the VE s2s is a wonderful contact, epecially on a homebrew antenna. I’ll bet there are not many G/VE s2s in the Database.
73 Mike
2E0YYY
Thanks Mike; the bands are wonderful in the evenings now especially 15m. Sometimes I just like to listen to QSO’s between the US and other continents whilst I am up there.
With the SA station I could hear the delay effect on his SSB signal as the paths converged here in Wales fascinating stuff.
Still not sure on the efficiency on my 5/8L 17m vertical though. I used thin wire for the counterpoise and I think this maybe a limiting factor. Credit goes to G6WRW for the idea, it really is a neat design that is simple to deploy and reduces the need to have a coaxial feed up to the upper part of the pole. If I re-designed my linked dipole I think I would have the Balun at the bottom with a ribbon feed up to the top to reduce the weight.
Hardly a breath of wind last night either. It was so nice.
I think my next challenge will be something with directional gain that is easy to put up, I did have a go with a Moxon - but with limited success mainly due to keeping the shape and the height retaliative to the ground (15m).
Jonathan.
