I have been using the CA2RXU firmware and a Heltec device myself (from Richard G3CWI here, so not one I bought randomly from an online tat shop ). If you can find any way of making it connect to a Samsung via Bluetooth so spots can be sent, please could you let me know? I’ve tried with various phones (from a very old S4, to the latest S25+ and none will connect).
Could you specify which Heltec board you are using and which version of the CA2RXU firmware?
Because the LoRa-APRS-Tracker version does indeed have a KISS TNC component that works seamlessly with BLE on the Lilygo T-DECK Plus , and the Digipeater/IGate version works via Wi-Fi on the Lilygo T3 V1.6.1
I’m not sure your filtering is working. Most of those stations are LoRa (all the stations in green with U or V are LoRa on your picture).
Considering that:
I don’t have an APRS 2m radio, and I still doubt that I could reach any digipeaters except from a summit (the valleys are on a narrow north-south axis, so propagation east-west would be very mediocre in the valleys).
I’ve also wanted to try LoRa things (MeshCore / Tastic / APRS, etc.) for a long time.
I finally ordered a LilyGo T-Echo 433 MHz. That frequency is not good for meshtastic but good for APRS I guess.
Hi Fabrice, I will get you the details tomorrow, as I’m down in London today for a cyber conference. Apparently AI going rogue isn’t good for cyber security…
I have two HTs that have APRS, Anytone 878 UV I and FT2DR. I have used both for tracking beacon and for SOTA spotting.
Neither are easy to use. I’ve never succeeded in sending an APRS to SMS despite setting it up. With the Anytone there is a timeout which makes it very hard to transfer information to the screen for me, with a clunky multi-click keyboard.
So I would theoretically use it more than I do, but haven’t bought an HT with a KISS, and in fact have not even turned on my HT in the past few activations.
I think the issue with some of the Heltec boards was that they only supported BLE, not Bluetooth classic and APRSDroid does not support connections using BLE (unless that’s changed recently).
Other Android apps are available which work with BLE but I haven’t tested it. Bluetooth Serial Terminal is one and it works with Bluetooth Classic but it’s not as polished as APRSDroid for APRS tasks.
