Continuing the discussion from 20m to VK/ZL to EU open daily to QRP - give 20m a go! (Part 1) - #101 by ZL4NVW.
Previous discussions:
Hi Matt,
He was TM2IF and in F/CR-204 op Roger @F5LKW
73, Ăric
Sorry. Yes conflating the TM15SOTA and special TM2IF calls when I posted. The call is correct in my chaser entry. But I did have the summit correct - TM2IF was used on several summits that day by several operators. The operator was F5ODQ - from the following spot.
22-04-2022 07:08:45 TM2IF SOTA [F/PO-207] 14.310 SSB F4WBN F5ODQ Op. CQ here, last activation 2014 !
Just checked and you worked @F5ODQ (OP) on F/PO-207
EDIT: change of plan due to low cloud wx forecast.
I am aiming to be on GM/ES-030 around 0530z Sunday. FT-857 and 30-40w into a vertical.
Internet coverage may be an issue, so possiby wonât be able to chase summits. Iâm likely to SMS self-spot and weâll go from there.
VK space weather forecast for today (Sunday) remains at enhanced MUF levels. Current MUF is enhanced by 20% over the predicted MUF.
The propagation forecast is all positive
Andrew VK1AD
Charging my batteries ready for a return visit this arvo. Did well yesterday and the weather was kind.
May as well get into it before the winter gales and snows appear.
Wal VK2WP
I went out again this morning 0615z-0715z, antenna pointing towards VK/ZL.
I heard @VK2WP but I donât think he heard me and I couldnât break the pileup with my 5w. Also heard a couple of other VK and ZL stations working him.
No VK/ZL seen on FT8, but there may not have been any FT8 operators on at the time.
I couldnât stay any longer as I had other stuff planned for the day, but went back up later unsuccessfully chasing NA S2Ss.
Iâm going to have another go tomorrow on 20m SSB after almost managing a QSO into ZL today.
I gave this a try yesterday. I set up at VK3/VC-031 Arthurs Seat which is also VKFF-0750 Arthurs Seat State Park.
Equipment for 40m was FT817ND, 5 watts, and an Inverted L . 20m was FT450D, 100 watts and a droopy ground plane on a squid pole.
A small sample of the pile up is at https://youtu.be/WzVYCbxqwwM Itâs only 30 seconds because I was filming with the same device I was logging with.
I went QRT at 0800z as the sun was setting with 65 QSOs, 15 countries, in the log and packed up in the dark.
Thank you to all who called me and my apologies to those I couldnât work.
Yep. Thatâs what it sounded like. Except without the strong ZL1TMs there much of the time. And if you didnât call one in, it just went on, and on! Over & over & over the top of each other.
Think of all the times Iâve spent hours calling into silent bsnds for that 4th qualifying contact on 8+ point summits. Darkness encroachng, camp several hundred vertical meters below. Loitering on 80m around nets and QSOs in the hope if snagging a contact as they finish up.
What a difference a few months makes!
EU chasers calling over the top of ZL2ATH/p while I am trying to complete a S2S. Very rudeâŚ
Listening for MM0EFI/p on 14.3275.
Andrew VK1AD
I started my activation yesterday (DL/MF-112) with a S2S with Matt ZL4NVW (ZL3/CB-451) 5:36 UTC and finished it with a S2S with Peter VK3ZPF (VK3/VC-031) 6:44 UTC.
Equipment: KX2 @10W and a simple 5m vertilcal wire on a pole.
It was hard to get the big grin out off my face for the rest of the day.
Thanks so much, also to all the other chasers during this activation.
73, Chris
DL3EC
I could not take part in the NA <-> EU S2S Party yesterday afternoon so I decided to try to work some DX today morning ⌠and I succeeded! ![]()
Started at the parking spot at 04:45 UTC and after an easy 20 minute walk I was on top of Eiskogel, OE/OO-084.
After the miserable weather yesterday I had luck this morning with a few hours of sunshine. I set up my station right next to the summit âŚ
My setup was:
I could work @VK3ZPF right away at 05:19 UTC, after that I started calling CQ on 14.320. Within 1/2 hour I could make contacts with @VK1AD @ZL1TM @ZL2ATH @VK3GTV @ZL4NVW and @VK2WP. Been listening for @VK5HAA also but his signal was a bit too weak for a QSO.
I was really struggling to get @MM0EFI in the log, but with his patience and good ears it was also possible! After working the usual EU chasers suddenly @VK3CAT called in at 06:37 UTC.
After working two local stations on 2m FM I started packing up at 07:00 UTC. It has been a pleasure to work 5x into VK and 3x into ZL ⌠it was worth getting up early!
73 Martin, OE5REO
I had a short attempt from FL/NO-087 again this morning. I could just about hear @VK3ZPF on 20m and he heard me calling S2S and responded but we couldnât complete. I thought the band was noisy compared to yesterday which probably didnât help.
I briefly called CQ on 20m CW but a quick check on RBN suggested my signal was barely getting out of Europe and I couldnât hear any of the VK CW operators.
But it was still an enjoyable session despite the lack of obvious success.
John
My activation of Isaacs Ridge VK1/AC-041 & VKFF-0845 started quite well at 0515 UTC on 14.310 MHz working Matt @ZL4NVW followed by OH1MM, OH1XT, G0VWP and a few others, the activation was proceeding well âhappy placeâ. At 0525 I heard Wynne @ZL2ATH call me with a âSummit to Summitâ, at this point I had 5 contacts in the log. Next, two EU stations a âSAâ and an âIKâ repeatedly called over Wynne 4 to 5 times both with huge 5-9+ signals. I was very angry shouting down the microphone telling them to stop and each time saying âZL2ATH Onlyâ âZL2ATH Onlyâ, yet they continued
Great examples of very poor behaviour on air.
The message eventually sank in and I did complete the S2S with Wynne, thanks Wynne for persisting
With one completed S2S in the log I was surprised to hear another S2S call, this time Martin @OE5REO at OE/OO-084. Thanks Martin for the bonus OE summit.
After working Martin I QSYâd to Fraserâs @MM0EFI frequency 14.3275 and listened for 10 minutes but no joy. By now the EU chasers may have wondered where I had go to, I did think of not returning to 14.310 MHz and instead just spend some time listening for S2S contacts.
I later went back to 14.310 MHz and the EU pack had got the message via a new spot, âBe Patientâ. At 0634 I moved to 14.330 MHz and posted a spot âLooking for S2Sâ hoping Fraser would see the spot. Next at 0630 UTC Peter G3MLO called me out of the blue from the South East of England with an impressive 5-9+ signal, my sig to Peter was 55. That was an indication I may hear @MM0EFI/P. Sure enough at 0646 UTC I heard Fraser call S2S
and we completed a 5-5 exchange. Thanks Fraser for your persistence, I am over the moon to have completed a 2nd GM S2S in two days.
I completed my activation of Isaacs Ridge with a 5-2 S2S exchange with Peter @VK3ZPF at VK3/VC-037. Thanks Peter
Summary: Setting aside the poor behaviour demonstrated by a couple of EU chasers, I note 2 and I am sure the rest of the EU pack would not behave in the same way, the long path opening produced 55 SSB QSOs and a new country Norway courtesy of LA3VJA. For the propagation nerds my timings were 0515 UTC to 0700 UTC.
Isaacâs Ridge VK1/AC-041
Inverted V dipole with the apex at 7m. Edit: Antenna is broadside East-West with the elements North-South.
FT-857D @ 25 watts
New countries: Norway and Lithuania
Thanks all chasers and activators, I had loads of fun working the pack and the challenges of S2S QSOs.
Thatâs it for me. I am planning to be in OE in May and at FN on Friday 24th of June with Herbert OE9HRV.
73, Andrew VK1AD
For my effort today I went to my closest summit VK3/VC-037 that is within VKFF-0753 Bunyip State Park. From home earlier in the day I had worked Ron @VK3AFW when he was activating VK3/VC-037 and when I arrived on the summit he was still there. We chatted for a while then I moved away about 50 metres and set up my 20m droopy ground plane and FT450D and started looking at spots and calling on 20m.
First in the log at 0439z was S2S with Wynne @ZL2ATH at ZL1/WL-153. A few minutes later was S2S with Wal VK2WP at VK2/CT-007.
At 0520z I worked Martin @OE5REO at OE/OO-084 for my third S2S. At 0543 Col @VK3GTV was the next S2S at VK3/VN-016.
At 0618z I went looking for S2S with @MM0EFI Fraser and while the exchange each way was not good I hoped we had made the QSO.
At 0636z I again went looking for @MM0EFI and, with a better copy this time, I was able to confirm my first S2S to Scotland.
At 0700z, as the last QSO for the day, was @VK1AD Andrew at VK1/AC-041.
I made a total of 71 SSB QSOs into 21 countries.
Droopy ground plane on 9 m squid pole, nestled among burnt eucalyptus trees
FT450D @ 100 Watts
A Misty Morning on Carn Ealasaid GM/ES-030
Another 0330z alarm call
I had plans for an early start and a long day in the hills including some VK summit chasing. However, a late return from the Speyside Stages rally yesterday evening meant little time to prepare, and to be honest, little appetite for a big day on high tops, especially as the WX forecast was for low cloud until mid-afternoon.
I set off from home at 0345z, heading up to the Lecht ski centre. Cloud was handing in the valleys but the tops were clear and I could see the summit of Carn Ealasaid as I approached the ski centre.
However, the ski centre was fog bound, with visibility so bad that I didnât see the ski patrol hut until I was nearly at it.
I set off at 0415. following the gravel ski road steeply up to the ridge before turning right across the top of the tows and on to the top of Beinn aâ Chruinnich. Then a sharp left, heading south and unfortunately descending across short heather and peat hags to reach the spot height 694m on the map.
On a clear day it is easy to avoid the peat hags. Today I couldnât see 50m, so I had to just head over what ever terrain I came across. The 694m spot height is right at the bottom of the deepest peat hag! Thankfully, once I had clambered out I found a narrow path that led right up to the Land Rover track that traverses the top. Time for ascent was 45 mins.
Summit temperature was 0C and I noticed that the fog was freezing on my pack.
The station today consisted of the Yaesu FT-857d, 5m of RG-174 (plus common mode choke) feeding into an âUpper & Outerâ monoband for 20m. This was suspended from a 7m pole (only 6m erected) which was simply wedged into the rocks of the summit cairn.
By the time I got on the air, I could already see some spots from VK & ZL stations on 20m SSB. Tuning around revealed no signals of any sort, so I spotted my own frequency and called CQ.
After several calls, at 0530 I worked SV7LNE and then LZ1WF. Then nothing for the next 25 minutes. Absolutely nothing! No answers to my CQâs and no evidence of anyone else when tuning around.
Then at 0603 I worked strong signals from SV1RVJ. SV2SOQ & FY5KE, so at least I had qualified the summit as a consolation prize.
Looking again at SOTAwatch, I saw that @OE5REO/p was looking for DX from OE/OO-084. Iâm sure heâd be happy with Scotland, so I called âSummit to Summitâ and we had a QSO, although it wasnât easy! Now it was 0614 and Iâd been QRV for an hour, with still no DX.
I was considering packing up. My bum was numb, I had a dead leg, cold hands and everything was getting covered in the dew.
Tuning around again for one last time, I could hear the VK stations coming up through the noise!
At 0617 I got @VK3ZPF/p in the log with 4/1 received. He was on VK3/VC-037. It was a difficult QSO and I wasnât sure that weâd completed it, because as usual someone got impatient and started calling.
However, at 0635 he came back again, much better and with 5/1 this time. I then found @VK3ZPF/p on VK3/VC-037 a minute later, also 5/1 received. Then after a couple of other stations OM1AX & OH3GZ, I decided to have one last look for Andrew @VK1AD/p. I found him fairly quickly. His signal was definitely going to be workable, however he was working a big pile up, as EU was now awake! At his first âQRZâ, I jumped in with âSummit to Summitâ and got straight in. He gave me 5/5 and he was 5/1 to me.
Awesome! Three VKâs in the log in really marginal conditions between VK & GM, all summit to summit. Add the summit to summit with OE5REO, that made four. Happy days.
I packed up in no time at all, leaving the top at 0700 and was down at the car 40 minutes later. I somehow managed to avoid the worst of the peat hags on the way back. I made it home for 0800z and got some pancakes on for Mo, who was just thinking about getting up. (She thinks Iâm mad, by the way.)
Amazing morning. Kit drying out and I still have the rest of the day to get up to no good!
A huge thanks to the VK stations for persevering and for picking me out from the pileups. Congratulations to Martin OE5REO for his outstanding log too.
Fraser
Well done Fraser,
An effort deserving of a great pile of pancakes.
Ron
VK3AFW.
Thanks Ron. Yes, the pancakes went down well with plenty of hot tea!
Cheers, Fraser
