Upcoming IT Changes - Mon 28th Oct 0000 UTC (Part 1)
Looking through the Alerts the blank space in the summit code is wide spread. Is this a migration issue?
Andrew VK1AD
Yes, it looks like the data dump from the old database automatically padded the association field.
Spots after 0804 UTC may not be populating the Spots Tab. See the two screen shots.
Andrew VK1AD
Hi Andrew,
Lost my alert for tomorrow on new SotaWatch, but still again on Sotl.as !
Nice Upgrade :+1:
73, Eric
RUDDY HELL.
Bit of eye openner wil take little getting used to
Not expecting that
2E0FEH KARL
I say WOW, looks great and clean. Thank you Andrew, great work.
73 Marek
Might be a browser refresh issue - I closed the Browser Tab and re-opened it then the later spots appeared.
Port-A-Log is still sending to the older server, and Peter will send an updated version when he lands in the UK later today. The SMS testing is Andy. Whatever app you’re using there is still pointing at the older API2 instance.
Edit :
It appears that there is a problem with the connection between SotaWatch and Sotl.as. I can no longer log in…
Remove your cached login for SOTl.as.
SOTA Goat.
Andrew VK1AD
sorry don’t work :roll_eyes:
It’s a problem on SOTL.as side, it appears. Manuel is back from his holiday soon and should be able to resolve it.
Merci Andrew
My SOTL.AS log in and other functions are working fine.
Andrew VK1AD
Not working for me on FF, even after remembering to follow my own advice and actually clear my cache.
This is fixed.
OK, I’m going to take a break. I am noticing that there are a few people in the logs who are having failed logins because their username contains a leading or a trailing space - so whenever they created an account back in the day, they’ve created a username with the space (Apple browsers are quite helpful that way), and now, post migration, they’ve been forced to re-enter their username and password and are missing the space.
They can easily fix it once logged in by editing their username under Update Account.
Failing also on the Italian SMS gateway, problem seams to be a connection refused from sotacluster
@GM4LLD I’m sending you detailed error info via PM
73 de IZ3GME Marco
Yes, you are correct Andrew :slightly_smiling_face:. I’m not logged in to SOTL.AS even though the login page didn’t report an error.
I tried to post a test Alert for tomorrow…. Oh look I’m not logged in!
