Friends new to SOTA consistently compliment the number and sophistication of the web-based tools we have. Thank you for all the improvements and maintenance to keep them all up and running!
73 Paula k9ir
73 Paula k9ir
There will almost certainly be a delay to this as the import of users from the old SSO server is going slower than expected and triggered a timeout overnight, so was restarted this morning. There’s 650 files of users to import and we’re going about 1 per minute and it’s been going for 2 hours already, so only about another 8(!) to go.
OK, we’re almost done - I’ve had to import via a different method as the previous method was getting slower and slower because it held a massive transaction open that was chewing up more and more memory.
Into the 560s now of 650 files and tracking at 10-15 seconds per file (each file is 50 users). I expect I should be ready to begin the cutover around the 0600 UTC mark.
First cutover for SSO about to happen, but I’m going to have dinner first.
Cutover starting - expect some weirdness in the next few minutes with SSO logins. Any existing login sessions will be reset.
Working in VK1 on my mobile iPhone ![]()
Andrew VK1AD
Thanks Andrew, a few things to tidy up in the backend, but we’re largely there.
Users please note: You may need to clear cache for sso.sota.org.uk if your browser is caching an older token.
Working here in the UK on my ancient Samsung tablet… and WOW, it blew my socks off! I wasn’t expecting such a change visually. ![]()
I had to clear my browser cache to reset cookies
OK, Spots and alerts are now synchronised between the two instances. I may have inadvertently deleted a spot or two during the sync process, but I don’t believe so.
Quick logging is working, no problems.
Andrew VK1AD
Anyone tried SMS spotting? Failing via my ZL SMS gateway currently … but is it working via the main UK SMS gateway?
I’m going to bed! Will fix in the morning if the issue is at my end!
Where does that route to? Back to Andy’s main spotter?
Yes - to Andy’s gateway. Will take a quick look and see if its SSO or the spot itself failing.
The spotter is suspended right now.
RR. Will check in the morning then. Thanks for letting me know - won’t lose sleep over it now!
Here is starting slower than before but works
73, Jarek
Just had a look at the new SOTAwatch design and I have to say it is looking great …
Thanks for the work to all people involved!
73 Martin
OE5REO
