It looks like the client library that Manuel is using just needs an update to a newer version. If I get a chance tomorrow I’ll see if I can send him a pull request with the necessary details.
Same here, Sotl.as not working on FF Edge and Chrome.
Login button not working.
Thanks 73
Fabio
Thanks for the report. Having established it is a bug, can everyone else please not add a “me too” to this thread.
Done – logging in on sotl.as and posting spots/alerts should now be working again (and using the new api-db2 URLs).
Just added and quickly removed a QRT Spot to see what it looks like… love it!
APRS2SOTA is now using the new API - I am not able to test posting spots from the Office, but I can see that it is on-line and I can query spots / alerts remotely so it should be ok.
I will look at implementing changes to use the ‘TEST’ and ‘QRT’ spotting options soon.
Andrew,
Thanks for your work on this major upgrade.
Ron
VK3AFW
Ham2K PoLo phone logger logger not working with spots (read or write). I’ll inform development team (if they don’t already know)
Issue is already opened on github
I’m working with them in the background to sort out the issue - they have spot fetching working AIUI but there’s an issue with SSO.
Spots are ok on ON6ZQ site SOTAwatch Filter, but not in Sotawatch
73 Fabio
I’ve turned off test spots and QRT spots - yay!
Adding a test spot, I get the following screen:
I think that text should say “Mode & frequency are NOT required” not “Mode is required” - as for test or QRT spots, the mode and frequency fields are used to display Test or QRT text.
Question - do we know if the App developers of SOTA Spotter or SOTA Activator, Polo etc. will be adding this separate Test/QRT button or will this just be on the SOTAWatch3 screen?
Thanks @MW0WML and @OE5JFE. Aware of the issue and @VK3ARR has been helping me out this morning. Will be taking a look at fixing login issue when I finish work today.
Most likely not as Bogdan has not been supporting the app due to personal issues.
I would recommend to give up on the app for the moment.
I am also not promoting it to newcomers anymore in my talks.
73 Joe
Boys and Girls, some of you are not reading the instructions. You always enter a spot frequency in MHz. Some of you are entering in kHz so the display is wrong.
i.e. HB9HCS/P is being spotted by 9A1AA as operating on 14.3 GIGAHERTZ ![]()
Please everyone MHz, no doubt this will be closed up soon.
Is this issue related to the IT upgrade?
Trying to login and and get the error
I can login ok to the reflector/sotawatch
cheers
john
Has RBNhole also to be updated? I see Hans HB9CKV with RBN spots, but this data is not displayed on Sotawatch etc. (and not on SOTAwatchFilter mentioned above), despite an existing Alert:
73, Markus HB9DIZ
Check your filters. When I looked it only had CW enabled. I changed it to all modes and HB9CKV/P is now there.
