Having been with my current employer for 10 years, I’ve got this funny thing called Long Service Leave. Since the original purpose was for those in the colonies to sail back to England for a holiday, I’m doing pretty much that, minus the boat bit.
My original intention was to finish mountain goat with the summits of the first day of SOTA but due to recent surgery and developing weather systems off the east coast here, I’m only going to get within 110 points before departing VK. That’s almost certainly too much, but lets see. At the very least I’m going to have a ball farming unique callsigns for the 10m challenge.
Arriving Friday June 7th, I’ll spend a few days in London with friends, then from Manchester, drive up to Fort William an stay there for 5 nights with the obvious goal of activating GM/WS-001 Ben Nevis. Normally tackling it via the CMD Arete would 100% be my kind of thing to do, but that’s probably not realistic for several reasons, so probably the tourist trail. I have the pair of Ben More GM/SS-001 and Stob Binnein GM/SS-002 in mind and also some distilleries…
Sat 15th - Mon 17th I’ll be based in Ambleside Lake District. Of course Scafell Pike G/LD-001 is the priority, and to be honest I may be more focused on sightseeing/photography but Helvellyn G/LD-003 is another option.
Tues - Sunday 23rd I’ll be in Wales somewhere. Again Snowdon GM/NW-001 is the main goal…probably via the Pyg/Miners track. My intention in Wales is actually to stay around the Mach Loop with the hope of the right weather conditions and timing for low flying aircraft.
Sunday evening I fly to Munich and will spend a week based in Friedrichshafen. I’m catching up with another VK operator and will plan to do some summits in southern Germany, Lichtenstein and Switzerland, along with soaking up the Euro 2024 atmosphere.
Since I’m travelling solo in the UK, I don’t have any pressures so planning will be largely weather, mood and more important, physical tiredness dependent.
If any one has any suggestions of summits that are “must dos” in those regions I’d be interested.
Questions:
I’ve packed wet pants, gaiters, and my regular (good) hiking boots, but do I need to consider more serious wet weather shoes such as gum boots? Multiple boots for one pair to be drying?
I’m going with the tactical mini pole from Sota Beams with a guying kit, along with some other light poles as backup. Are there any concerns I should be aware of regarding types of pegs to be used? Is aluminium okay on UK summits? I’ve been practicing setting up in windy conditions but not sure I’m completely prepared.
I’m expecting serious crowds on at least 3 of those summits. On Snowdon at least, I plan on being handheld on 10m and probably 2m with a mini whip. Otherwise probably the half wave vertical for 10M and a trapped EFHW for 40,30,20. Any etiquette concerns I should be aware of?
Andrew VK3JBL
