tSotaLog: Fork of general purpose FOSS logging app TOTALOG
Hope to catch you on the bands some day :smiley:
Hi Beni,
Thank you for your answer, fully agree with your approach.
issues/26 I would qualify it as an enhancement rather than a bug, but it is up to you xD
I put some thought into this issue and realized that I’m not sure how to implement this. Two questions arose:
  • If I pre populate the field with the date, the pre populated export file name doesn’t make much sens anymore as it it <date>_<name-of-archive>.[adif|csv]. So how would implement this? Prepopulate the archive field with <date>_<summit> and then export to <name-of-archive>.[adif|csv]?
  • How do you define the most relevant summit reference? Say I activated two summits that day, XX/XX-001, a 8P summit, with 31 QSOs and XX/XX-002, a 10P summit, with 30 QSOs. Which of the two is now the ā€œmost relevant summitā€? Does the amount of QSOs precede the amount of points or vice versa?
Beni
I tend to consider annoying usability issues bugs rather than enhancements. IMHO only a annoyance free app (as far as feasible) should be considered bug free… :wink:
Hi Beni,
Thank hou for your message.
In my mind, I would always do: 1 summit 1 archive, because it is how I think it will be good to keep stuff organise and sorted. But… others my organize things around their journey.
Export it has what is inside the archive field, with a bit of trimming (space and / in case there are any).
Again, I will do two archives, one for each summit, because I think it is how I would like it to be archived, but it is only me. Regarding your point, if there is one summit, easy, you keep it’s label, if there are several summits, in first intention, I was proposing you to take the one which have the most number of QSO (not points, for me points are not so important, it is how I enjoy in my day that is!), but it will hide from here that there is another summit behind. Finally with a better analysis in case of multiple summit, why not using tag ā€œMUTLI_SUMMITā€ instead of any summit ref, what do you think ?
Thank you Beni
LƩopold
IMHO the app should be designed to accomodate either way of managing logs, yours - i.e. archiving per summit - and mine - archiving per activation and sometimes even per multi-day activation. So I’d suggest we check whether there is a unique summit in all entries and if there is we pre-fill the summit. It it’s not unique, we stick with the date of the latest log. What do you think? That way we don’t have the problem that one summit might be hidden from the archive name. After all it’s just a preset and can be changed before archiving… I’m not very fond ot hard coded general names like MULTI_SUMMIT. I’d prefer to leave it up to the user to enter anything but the date.
Hi Beni,
Looks like very good!
Thank you for being so open!
LƩo
It’s only an issue up to now, now code has been written… :wink: I don’t have a huge amount of time to spend on the project, so expect it to move slowly but steadily…
Now that summer is definitely over I found some time to tackle some of the open issues and published a new release candidate
@F4IYY If you save a log to history, the name now defaults to YYYY-MM-DD XX/XX-000 if the summit of the activator is unique or empty for every log entry and to YYYY-MM-DD otherwise.
Let me know if you discover any issues - either here or on codeberg.
Are you planning to distribute this via F-Droid?
Try https://ea7gv.ure.es/LogEA7GV31.zip
I developed it for my activities, now it has an interface in German, English and Spanish, the manual is also translated. Read it to know all its features.
73 JosƩ
I tried to submit it to F-Droid but failed to get all the npm dependencies to build from source on their build server. Eventually I decided it was too much effort for something with such a small user base. Details on the merge request: ch.hb9hnt.tsotalog (!10726) Ā· Merge requests Ā· F-Droid / Data Ā· GitLab
You can install if in F-Droid from the IzzyDroid repos. They just pull in the apk from my release page: tSotaLog - IzzyOnDroid F-Droid Repository
May I suggest that you start a fresh thread for your app since it has nothing to do with tSotaLog - as fas as I can tell, at least.
I thought you were looking for an app for activities and I didn’t read the rest. Excuse me.
73 JosƩ
Used it today Beni, works FB :+1:
Lost all my names when I switched phones the other month so I’ll add them some time. Otherwise nice work.
Hi Alex
You may add names and callsign with the names.csv from here
https://hb9sota.ch/wp-content/uploads/2023/09/names.csv.
Download and import into tsotalog.
Enjoy
73 de hb9fvk
@hb9fvk Did you successfully load this file? There are still some open issues around loading large CSV files
I haven’t worked on these because I only use my own CSVs containing people who actually told me their name on air at some point. Of course I wouldn’t mind if this magically fixed itself in the meantime…
Hi Beni, no Problem loading the File just downloaded from Stephans siite.
73 de hb9fvk
I’d avoided uploading the big list for that reason, just the usual chasers but thanks, I’ll upload them now.
Tnx
Let me know if any issues come up. It’s about time that I improved that names interface, anyway…
It all works Beni, if you look in the callsign view on my phone then it doesn’t quite want to load but on the Log tab names all get pulled in ok, so not really a problem
