Three Becomes Two Becomes Three
With a mystery Monday off work (don’t ask questions, just accept the mysterious gifts) and a reasonable looking weather forecast, I decided I would stick the running shoes on and head to Fife for a loop of three summits in a single day out - East Lomond (GM/SS-198), West Lomond (GM/SS-154), and Bishop Hill (GM/SS-187).
This was where I’d had some of my very first experiences of Outdoor Stuff™ as an Air Cadet, doing my bronze Duke of Edinburgh expedition up here many, many years back, and I figured I could still more or less remember the lie of the land. Although the forecast was generally pretty good, I knew it’d be a wee bit breezy, but mostly, I was expecting a good covering of snow after seeing a pal walking up Bishop Hill the previous Friday.
I was a good bit later than planned getting started. First off, I’d driven right to the on-ramp of the motorway before realising I’d forgotten to pack my microspikes for over the trainers, and I figured I’d more than likely need them. I drove home, nipped back to the flat, then swore a lot as I completely failed to find them, eventually remembering I’d left them in the boot of the car “so that I wouldn’t forget them”.
My plan was to get up to the wee car park at Craigmead, which with its elevation of about 280m would act as a good headstart, and work as a nice central point between the three hills to give contingency options if needed. Of course, I drove into Falkland just to find the road up to Craigmead closed, and had to do a bit of mental scrabbling around trying to work out if detouring to the Glenrothes side would be possible, or if that would even be open at all either. Eventually however, some of that old local knowledge resurfaced, reminding me that there was of course, a car park at the mast site just to the east of East Lomond, and with even more height to start with at 340m elevation!
So, off I went, very quickly justifying the making sure I had my microspikes on the short but steep ascent to the first of my hills for the day, East Lomond (GM/SS-198). The previous days’ snow dumps had been trampled down into slush, and that slush had then refrozen into a nice hard sheet of deathtrap ice. Thankfully though, there was enough soft stuff on the steeper slopes approaching the summit lump, and I was able to make fairly easy progress to the top.
As I was getting set up, I had a horrible “it’s going to be one of those days” feeling, as the wind caught my logbook and favourite pen and blew them across the hillside. Thankfully I was able to catch the logbook before it fully turned into a kite, but my trusty RNLI Parker pen was nowhere to be seen. I really liked that pen (an older Parker from before they turned a bit cheap and crap, with a fisher space pen refill inside), but as it was one I’d found lying abandoned at work, I figured it was only fair that maybe someone else gets a lucky find some day (and hopefully not some unfortunate local wildlife). Its dark blue body being hard to see justified my usual method of buying bright orange pens so that they’re harder to lose.
Anyway, after a bit of faffing, I managed to get six contacts in the log fairly quickly, fighting the wind for that one solitary point. I’d brought my Yaesu FT-65, but noticed I was getting about S5 background noise presumably from the nearby mast site, so I decided to put it away and bring out the filter big guns with the trusty FT-270, and had no problems at all. The antenna for the day was a Chinese RH-770 clone, which seems to go pretty well. Question time: does anyone UK based know anywhere that has genuined RH-770s (BNC) in stock at the moment? I can’t seem to find any real ones, just a lot of clones.
Next on the itinerary was the slightly taller of the two Lomonds, West Lomond (GM/SS-154). After doing a bit of negotiating on the way down off the summit lump, there’s a pretty easy big track between the two hills, passing by my planned start point at Craigmead. Again, this was mostly refrozen slush and was a wee bit tricky to pass in places, even with the microspikes on, so progress from East to West Lomond wasn’t quite as quick as I would’ve liked - my usual running had turned into a bit of a bambi-shuffle.
Eventually however, the track ended, and there was nothing else for it other than to humph it directly up the side of West Lomond. The photo above was a view back across to East Lomond from the slopes of West Lomond, where I was pretending to stop to take a photo but really I just wanted a wee bit of a breather from the one-step-forwards-two-steps-back way trek up through the soft snow. Although the haul up was hard work, it thankfully didn’t seem to go on for too long before I reached the top.
The ledge around the summit trig makes for a perfect seat, and this time I was a lot more careful not to lose my logbook or my one remaining backup pen. Once again, the chasers were out in force, and I was able to get seven in the log nice and easily in the space of about twenty minutes, before deciding I’d had enough of the wind, and calling it a day.
My original plan had been to drop off from West Lomond and head across to Bishop Hill, but I was starting to have my doubts about how hard it’d likely be to get across the rougher ground and how much daylight I might have left. With hindsight, I’d likely have had no bother at all getting over, as the ice on the big track between the hills had started to either soften up back into slush or disappear altogether, making the return leg a lot easier to pass.
While the steep snowy slopes of West Lomond had been a slog to get up, they were a lot more fun to descend back off of, with a wee bit of customary bum-sledging at times too.
Thankfully on the way back to the car park there was a nice detour track around East Lomond, and on looking back, there was a noticeable reduction in the amount of snow on the ground in the couple of hours I’d been out.
Once I was back in the car and thawing out, I was left with a slight sense of gnawing dissatisfaction at not managing to get Bishop Hill ticked off while I was here, so I hastily hatched a plan to try and get one more hill on my way home. As I was heading back towards Glasgow anyway, I figured I’d try and have a go at Cairnpapple Hill, about as close as I’ve seen to a drive-up summit in Scotland.
Although conditions were dry but cold and windy upon arrival, just as I’d got the radio out of my bag and got ready to put my first CQ shout out, a sudden very heavy shower dumped a whole load of freezing rain and hailstones down on to me, soaking everything before I’d even had a chance to retrieve my waterproofs. Picking up the contacts this time was slightly harder work, hindered by some audio troubles at my end as I fought the wind and the fact that my FT-270’s mic hole ended up full of water.
So, all-in-all, seven points for the day (two single-pointers, and a two-pointer with three-point winter bonus), and very numb hands. I’ll just need to nip back and do Bishop Hill some other day.
East Lomond Activation Data: Sotadata3
West Lomond Activation Data: Sotadata3
Cairnpapple Hill Activation Data: Sotadata3
Strava activity link: The Two Lomonds | Strava
Was this just because of recent snow etc. or is there another reason? I’m sure the Craidmead car park is Pay and Display or such now too.
Exactly. Brilliant piece of kit :wink:
I’ve got Fisher Bullet that is really quite nice. Your comment about Parker made me go and find which Parker ballpoint (with a genuine refill) I have. It’s a stainless Parker Sonnet and apparently a new version has an RRP of £80. Ow! I didn’t pay anything serious for it but I could have had it 30 years now.
The view to West Lomond along the track is rather good.
That wasn’t forecast at all. It was meant to be greyer than the quite sunny day actually was. Myself and the hound enjoyed a walk just before lunch. I was playing with Pyrolytic cleaning on our new oven and noticed the sudden downpour. Boy does the oven get hot but it did about 75% clean up on the quickest setting. Lots of white dust to remove and most of the grease stains gone.
Shame you got wet.
I think it was just road works at the Falkland end, there were a few cars in the car park, so I can only suppose they must’ve come up from the Glenrothes end.
I’ve never tried any of their regular pens, but I do really like their refills, I tend to stick them in any Parker-shaped pens that I buy. Current favourite is an Ohto GS02 with the Fisher Fine refill.
The small mercy was that it was gone as quickly as it arrived, and I could see it menacingly sweeping over towards Livingston. Otherwise, yes, the weather was probably a few points better than it really ought to have been for most of the day, so one small downpour shouldn’t really be cause for complaint.
I set a stock alert on the various ham stores and eventually one came in and I ordered it.
If you want to carry a little more, the slim g and some small mast is a good option. Strangely cheaper to buy the slim g via ebay than direct…
This is a fair shout, I guess I will just need to be patient and see what comes up!
I’ve already got a Slim G and 4m fibreglass pole, which is a lovely setup and my preferred option if I’ve got the time and carrying capacity, but the RH770 (or my current clone) seems to be the best option for running activations, as it seems to get pretty close in terms of performance for a lot less pack space (although at the trade-off for durability I guess).
According to the Fife coast & countryside trust social media post from 28th Jan
Craigmead car park can only be reached along the road from Leslie. Not from Falkland. This is so the road can be cleared of debris after the storm yesterday.
Whether this is still the reason for closure, I am not knowing, although seems likely.
I managed these three in June. I think I had an equally windy day. I only did HF on the final summit (East Lomond) because I knew I had plenty of time in hand to nip back down to Falkland.
Aye, I think I’d maybe previously seen one of your Youtube videos from the Lomond Hills. Probably a bit more rewarding hiking up from Falkland, but the two high-up car parks definitely help with cheating your way to a wee bit of bonus elevation!
Here we are: Diamond RH-770 | 2m/70cm Telescopic Antenna with BNC Fitting – Radioworld UK in stock as of 7am today!
I have a clone and a genuine one. When I’m going out, I grab one from the pot that my many whips live in. Who knows which one it is I’m using? Not me. :sweat_smile:
Thanks for the heads-up, the plan worked! I got the stock alert email just as I was going to bed tonight, so there’ll hopefully be one on its way to me shortly.
I’ve had pretty variable results from Chinesium clones of various gear, it’ll be interesting to stick them head to head and see if there’s any discernible difference. From what I could gather on the internets, it looked like the clones were pretty comparable on 2m, but barely worked at all on 70cm. Not that I really use 70cm anyway, but y’know…
I did measure SWR my RH770 and a clone from aliexpress. Both were fine on 2m (1.1/1.3) but 70cm on the clone was much worse…it was 4.8 @ 433.5MHz. Of course more to it than that, but not a good sign.
There’s some guy who did a video on that.
..thanks Fraser for your report, very enlightning. I have the Diamond antenna, might try the counterpoise.
