On the occasions when you want to test the latest homebrew wire antenna at home, here is a temporary pole support which permits the antenna to be elevated and tested at a height that matches activation conditions.
Materials: 20 ltr Bucket, a length of 50 mm PVC tube and a bag of ready mix cement. Select a pipe diameter of choice.
On my first attempt……. the plastic handle quickly broke off. So on v2, I added redundant U bolts either side of the tubing so that I could put some rope across them and make a handle.
…and when it’s not being used for a mast you can use it for a brolly, get some extra shade in the garden, and pretend that’s what you really made it for all along…
I have done the exact opposite. We already had a very heavy umbrella stand and I machined a tube that would screw into the base. It is super solid. Plus, I get some exercise moving it around the patio.
The cursory similarity between my hexbeam and a clothes dryer has been drawn to my attention more than once. One friend even suggested he might pick a day when I was out to lower the mast, hang some laundry on the hexbeam, and put it back up to 40 feet…
Today, my portable 2 inch, 50 mm pole support spike in action at Mt Ainslie VK1/AC-040 and Black Mountain VK1/AC-042. Fortunately the wind was calm at both summits.
FYI, I worked Chris F4WBN at 10 watts from Mt Ainslie
