Hi,
starting from 04/12/2014 I’m seeing these two invalid entries in the exported file:
CU/CU-FA-002,Azores,Faial,Cabeço Verde,487,1598,-28.79694,38.5919,-28.7969,38.5919,1,0,01/12/2014,31/12/2099,0,,,
CU/CU-PI-002,Azores,Pico,Cabeco do Escalvado,1077,3533,-28.213954,38.440554,-28.2140,38.4406,8,0,01/12/2014,31/12/2099,0,,,
It looks like the Association code is duplicated.
The same summit codes appear on http://www.sotadata.org.uk/
Thanks for the headsup Stewart. This is a hangover from when the DB was extended to support Unicode characters. Everything uploaded since the switchover will be correct even if it uses non-Roman characters. Anything uploaded before that used non-Roman characters may be fine still. But it may have been converted to a best fit before and now gets mishmashed when the CSV is generated.
One of your hills listed shows as “South Piñon Hills HP”. However, instead of the codepoint for ‘ñ’ being in the name, ‘ñ’ is inserted.
