My second attempt to enter an activation with some S2S failed. During verification I get the message S2S not valid. I checked my Summit and all S2S and found no error. What I have done wrong?
Please post the .csv so we can see what the problem is.
The message says s2s not valid at that time. Was a summit new or had it been recently deleted Or end-dated?
There are *314 summits in zl3, four of them.
Maybe Andrew @VK3ARR can add a bit clearer messages which cell/row is the reason for the error message. Otherwise it is a guessing game.
One of the great things of the session restore is that I can pull in exactly what was submitted from the logs and restore it into my own browserâŚand trying that, everything works for me. Which doesnât help Chris.
I guess my request is try again, but have the Developer Console open (F12), and send me any error logs from there.
Okay I see how the 007 badge works. At first I thought I had the Lazenby badge because Iâd activated HB/BE-048, Schilthorn! I was doing Google searches on where other Bond movies were filmed to see what other summits might qualify.
Lol
this one
Unfortunately, after many attempts, it still doesnât work.
This morning I took my tablet, as I did for the last 3000 activations.I uploaded after 10 of 30 entries and wanted to continue.
Some entries were gone as well as all S2S.
I know my vague error message doesnât help you, Andrew
Looks like you have two logs for the same day and the same summit? At least on the top screenshot it is twice the same reference (the two blue headers have both DM/NS-122).
And the second screenshot states duplicate because those entries (like DL7FX/P) are already uploaded (with same time and callsign).
So I suggest to delete the activation for that day from the database and try an upload again with one csv file ? Or even better to just edit it. You can just add additional QSO via the form.
It looks like the first table has no S2S listed and the second has? You can enter the S2S now directly to the activation. No need for extra chaser entries.
73 Joe
I had a QSO with DL1CR/p. DL1CR/p was not spotet. When I enter the QSO via <Hochladen/Eintragen>, it is not entered in my chasser log. This was possible with the old database. How can I enter a single QSO?
73 Uli, HB9CGA
After the form did you press the blue buttons two time?
First it states Verify and then Submit log.
(Verifizieren und dann ändert sich der Knopf auf Log hochladen)
Many sites have been renewed lately.
Almost everyone fills the pages with useless images, special effects, colors, then itâs often difficult to find what you need.
Not the SOTA database restyling.
Congratulations, there is still hope in this world!
Dr Joe
Danke fĂźr den Hinweis. Nun hat es funktioniert.
73 Uli
Hi all,
Issue solved by myself
- after editing the log must be verified and uploaded again, editing only even after pushing âsubmitâ button is not enough.
After the above mentioned actions statistics are updating immediately.
73, Jarek
Just uploaded a log for vk5/se-001.
Of course missed old mate John vk5haa on my first csv file entry which I discovered when he did not show up on the Map segment after my upload. It was a rare QSO on 20m cw over a short distance so have to log it.
Floundered around in there and found itâs much the same as before delete the whole log and send up the corrected CSV and all is good. So senior moments are testing the system here but it all seem great so far and I could sort out my mistake.
Good work regards
Ian vk5cz âŚ
That will currently happen if no locator data is available from the internal or external sources (SOTA user profiles, QRZ.com, âŚ). In that case no line will be displayed.
But I think this system (and the other mapping features) will see improvement whenever Andrew @VK3ARR is motivated for the next challenge in SOTA IT.
In my paper log I still have a couple of s2s (former: chaser/s2s). (feb.23-apr.23)
How can I add them now to the database?
Thanks for any help.
Juerg hb9bab
Are the activations already uploaded ?
If yes go to (German version)
Hochladen/Eintragen
und dann
Log-Datenverwaltung auswählen
Dort kannst du jede hochgeladene Aktivierung bearbeiten.
Mittel des âBleistiftesâ kann du diese bearbeiten und die S2S dazu Eintragen.
73 Joe
