I didn’t hear you either
You got one more 2m CW QSO than I did! I called for a long time on 2m CW from G/SP-015, but no QSOs at all. 20 QSOs on 2m FM including 4 S2S was some consolation.
Apologies for my ignorance, Are we looking at using horizontal polarisation?
David
G0EVV
Mainly yes, although I tried calling with both H and V-pol yesterday.
Trying again.
It will help chasers like me with choice of both if polarisation is stated in the spot. You are pretty good like that Tom - you always spot your working freq after QSY from 145.500 and you always declare your TX freq offset on FT8, always a big help. Stating the polarisation used on VHF modes other than FM when spotting yourself should be compulsory!
73 Phil
Are you free to try a few modes on 2m now Phil?
Yes Tom but modes available here are limited to the popular ones. FM AM SSB CW FT4 FT8 RTTY PSK haven’t tried much else I’m afraid.
73 Phil
Shall we meet on 144.525 in the all modes section? I’m just completing an SSTV QSO there atm. H-pol.
Can try Tom as you have beam may work you. Moving my RX now after the excitement of working Vlad again RX9WT R9U/SO-064 on 20m CW split.
73 Phil
Tuesday evening seems to be fine weather. I set an alert for another 2m multi-mode activation.
FT-817; 5W; 2el delta loop (horizontal) and J-Pole (vertical).
Summit to be decided later. Watch for up-dates!
73 Heinz
Tuesday evening is the 2m UK activity contest night. 1800-1855z 2m FM, and 1900-2130z 2m SSB (and maybe some CW?).
I’ll be out on a hill for that, but therefore won’t be available to try at 1600z. But if you’re still QRV at 1730, maybe there is a chance? I should be just about set up then.
1730z should work for me. I will spot myself.
73 Heinz
The wx today is very poor and forecast to remain so through until late evening. I won’t be activating tonight.
I have been giving aerials a bit of thought for use on 2m CW. I think I have a cunning plan.
I have located 2, good quality HB9CV’s in the loft, along with a power splitter. The web says 4.2dBd gain per aerial. The stacking distance with the modest gain aerials being 1.3m That should deliver 7.2dBd at 4.5 m on a roach pole, minus 0.3dB RG213 line loss.
All I need is 2 paxolin squares to mount the aerials (at their centre of gravity) on the pole using a couple of cable ties. Simples.
Roll out the good wx.
David
G0EVV
David, if you going to go a bit of trouble to make a better yet manageable 2m antenna system then why not treat yourself to a length of LMR400 coax? It’s just a little over half the weight of RG-213 and over a 1dB less lossy at 100MHz and 2.3dB less lossy at 400MHz. I’m not a 100% sure if standard RG213 fit BNC or N connectors fit it though but crimp N connectors are only £3ea for it.
Hi Tom,
OK, understood. Thanks for the info. I have a forecast for dry and sunny weather and will activate later today!
73 Heinz
Tomorrow evening looks much nicer so I hope to be out for the 2m FT8 event 1900-2100z. Although I have a dodgy feeder to check…
I understand the point, lighter and lower loss but, I would only save 0.145dB and I would have to source the cable and N types. but I agree, every little helps.
David
G0EVV
The Propquest website is showing a possibility of some ES later today.
Aerials now ready. Summit identified.
Do we have a date(s) in mind?
David
G0EVV
