Edit: Sorry Adrian, I was in mid type with this post while your post had already appeared. I will leave my post as it is for now, other than to say very well done with 5 QSO’s on 160m
Original post:
Hi Andy / Karl,
Thanks for the photos, my experiment using a concave shaving mirror & a piece of card to view the eclipse whilst on G/SP-012 worked, but not as well as I had hoped as it was quite fiddly to focus & the Sun was mostly obscured by cloud.
Walt, I really do empathise with you & your noise problem, I too suffer from man-made, or un-natural noise at home on several bands. The noise levels on G/SP-012 Easington Fell are completely natural, if there is any man made noise, it sits so far below the natural noise floor that it becomes irrelevant.
Special thanks from me to other activators who tried Top Band today, Adrian G4AZS, Carolyn G6WRW & John G4YSS, who using his usual Scarborough Special Events Group call GX0OOO/P was first to answer my CQ today on 1832KHz.
Adrian, very well done on your first 160m CW activation, if you were using 5 Watts as per your earlier post, very well done indeed. My signal reports to your were genuine. Sorry for any confusion when you were trying to work OK1TN. He stopped calling so I called you to let you know you were stronger than you had been earlier. We were mid QSO when OK1TN started up again, safe to say, he couldn’t hear me either Hi!
Carolyn, You didn’t expect the lash-up you had made to work of Top Band, but it did, & very well too. Genuine 57 with me, with some QSB. No need to apologise for not doing CW, you don’t have to do CW nowadays, although some of us old fuddy-duddies still prefer to
John, what can I say, I knew you were going to be around but I did not expect the first reply to my CQ to be from you. I was pleased to hear a “G” as at least that meant someone could hear me. When followed by “X” I still hadn’t put 2 + 2 together & simply thought,club station. Before you had finished sending “0” I knew it was you & wrote the following “OOO/P” in my log before you had sent it.
If any one person has inspired the use of Top Band for SOTA activating, it is you. That alone makes you inspirational, but your own personal goal of achieving Mountain Goat purely in Winter Bonus points takes you to another level.
Congratulations on achieving your goal John, & thank you so much for the inspiration.
Of course, many thanks are also due to the chasers for simply being there
You can tell I’ve had a fantastic day, can’t you? Hi!
Thanks & very best 73 to all,
Mark G0VOF
