That’s my guess too and I would first try fitting some ferrrite chokes at both ends of the control cable between tuner and FT-817. In case this doesn’t solve the problem, I’d fit ferrite chokes to the tuner and FT-817 power lines.
Good luck, Declan!
Thanks for all the QSOs.
I just discovered this same problem on a SOTA activation last weekend. I had been using EFLW (41 feet) via 9:1 UnUn to a KX2 , no problems tuning on bands 10-40m. I switched to using my SW-3B and maAT-10 tuner. No problem on 20m or 30m , tunes quickly. I tried 40m and as soon as I TX within a second the SW-3B stops transmitting so cannot tune wire. I added wire to 58 feet but same result. At first I suspected maAT-10 but checked at home on my 40m dipole and vertical and the SW-3B/maAT-10 combo works fine on 40m. So, I suspect RF from the EFLW getting back in to the radio is the issue. I have added several clip on ferrites to the RG174 patch leads between the 9:1 Unun, maAT-10 and SW-3B and will try it out on a summit next weekend and hopefully this will allow 40m operation. Will post results .
Yep but strange it works fine if the 817 starts in SSB mode but not in CW mode, in both cases it switched to FM , Tunes, but returns to SSB ok but locks the rig rather than return to CW mode. I use the KISS (Keep it Simple Stupid) solution and just leave the control line at home
Dec
I hope DHL/Customs in Madrid will continue with my uBITX V6.
They have all Dates / Adress / NIE / and my confirmation for paying the 45€ fee - etc but its hanging there now for 4 Weeks…
My birthday and Christmas are within 10 days of each other. I asked my wife if it would be ok to purchase a radio as a combination present? She said, after 20 years of marriage at least your asking when making these $500 purchases! She never asked the actual price and I just let it slide.
I am fortunate to live close to DXe and picked this up last week.
Wasn’t sure about what to ask for this year’s Christmas until I got a clear message in the form of several reboots needed several times to make my old 2nd hand Sony VAIO laptop work.
It’s not only for SOTA but I’ll surely use it for SOTA and ham radio related things.
