I worked a contest station today on G/SE-001, well in the activation zone but they were operating from a vehicle.
Does this count as a chase for the summit?
The rules say the chaser must make a QSO with the summit expedition, but for an expedition to be considered valid operations must not be in or in close proximity to a vehicle - so I think the answer is no
Apologies, but if this contest station on Walbury Hill G/SE-001 was operating from within the activation zone, but from inside a vehicle, this is not valid for SOTA.
Sounds like they were contesting from a summit that happened to be within the AZ of a SOTA. If they were explicitly operating as an activator, it would have been invalid as SOTA rules say activator(s) must not operate from a vehicle.
Your QSO might have been valid for the contest [with the correct exchanges] but not as a SOTA chaser.
They are on the same summit for most GHz contests, and depending on the band, may be in the car, or away from it. Always worth asking where they are operating.
I have previously worked them on 5 & 10 GHz and Barry (G4SJH) was kind enough to provide proof of SOTA conformance.
Stuart, is that dish, tripod, table, etc yours or theirs? I would imagine it would be hard for a solo activator to carry all that GHz kit, and in any case one would need to pick an easy-walk summit.
Seems more like a POTA if you needed to drive off road to get within or very close to the AZ. The last SOTA I activated was Rombalds Moor. I walked to the trig point but you could park on a public road there and walk only a short distance into the AZ although not flat enough there for GHz.
3.5 Guidelines for the definition of a Summit
3.5.4. Summits that are accessible by road can still be included in the programme, although
operation from within vehicles or the near vicinity of activator’s vehicles is not
permitted
If the rule is about not sitting in the vehicle or having an electrical connection with it (which makes perfect sense to me) why bother even driving the vehicle away to be rule compliant (when “near” is not quantified)? I can see why you might want to move that large metal object out of the antenna’s near field, but otherwise… ?
I’m not a Harry Potter fan but apparently it’s a reference to non-wizards ie ordinary folk. And in the SOTA context I’ve seen it used to refer to non SOTA hillwalkers at the summit especially the ones who suggest daft explanations as to what the activator is doing with that strange-looking equipment.
The usual rule of thumb employed is that the car should be able to be driven away and the activation continue unimpacted. Ie, no part of the station can be attached to it, you can’t be in it, and it can’t be used to shelter from the wind or rain.
Near is not defined because near means different things eg to an activator in a wheelchair vs a 0% body fat, chiselled-abs triathlete (let me know if you ever see a ham like that). SOTA aims to be inclusive for all abilities.
The antenna to the left seems to look thru the antenna on the right. If they look in the same direction, I’d place them side by side, minimising interference.
