Proposal for a VK/ZL<-> UK/EU S2S event (Part 3)
Continuing the discussion from Proposal for a VK/ZL<-> UK/EU S2S event (Part 2) - #101 by G4TGJ.
Previous discussions:
FYI for all. VK1 sunset is 08:20 UTC, while VK3 sunset is ~08:40 UTC.
Andrew VK1AD
… just two days to go until the VK/ZL ↔ EU S2S event, and already more than 20 alerts have been posted! Great to see so much interest, including from friends in Japan – something we shouldn’t underestimate, as 20 m can open up from Europe to Japan in the (UTC-) morning.
One thing we noticed during the test run was that massive pile-ups can build up around activators in VK/ZL, creating an almost impenetrable wall for activators in Europe trying to get through with low power and temporary antennas.
Maybe we can improve the chances of making DX S2S contacts by regularly asking specifically for S2S during our activations. It’s just a suggestion, but it might help activators who would otherwise struggle to break through the pile-up.
One tip for CW operators: if you’re calling in a pile-up, don’t call zero-beat. Use ā€œXITā€ to shift your transmit frequency approx. ±100 Hz. This will help your signal stand out from the crowd and make it easier for the activator to pick you out.
I’m really looking forward to Saturday! The weather forecast here isn’t looking too promising, but we’ll see…
Whatever the weather brings, I hope everyone has a great day out there and makes some memorable S2S contacts.
73 and see you on the bands,
Roman
Hi Roman,
As far as the terrestrial weather goes, it seems it can go either way down here in Southern Bavaria. Some reports say dry until 9:30 am (local) and then a downpour, others are saying rain starts earlier.
As for the Space Weather, this morning was a disappointment, with only one VK heard from my home station on 20m LP, where there would normally be 5 or 6. The SFI has gone up, but conditions have not improved along with it. Fingers crossed that things are better for Saturday.
As for rude chasers blocking S2S contacts, this has been discussed earlier in the first third of this thread. I know it is very common in other schemes; SOTA used to be friendlier.
Given that this event is aimed primarily at activators working activators, it would be great to have a ā€œback channelā€ between activators to alert when calling another summit.
As a minimum, I recommend calling with /P at the end of your callsign, so that the activator being called may pick this up out of the melee, especially with the repeated ā€œsummit to summitā€ text (or shortened form for CW) in the transmission.
Most times (but not always), chasers will be home stations with more power and better antennas, than the portable activator, so providing a far stronger signal. I would ask again: those chasers who hear the faint ā€œSummit to Summitā€ in the pile-up can please tell the activator being called, that there is an S2S contact waiting - after all YOU called in over the top of that summit station, so it’s the least you can do.
73 Ed DD5LP/P
Hi Ed,
it seems the only question is when the rain arrives :cloud_with_rain:
I have now decided against the K3 and bring a TRx which is more weather-proof and easier to protect against the rain.
Fortunately the solar wind speed is already coming down again, and the proton density is slowly decreasing as well. Let’s hope conditions settle down before Saturday!
As for the back channel idea, I suspect it’s too late now to establish something like that before the event. But it would be great, if the regular SOTA chasers could point out S2S calls to the activator. I have great confidence in the SOTA community here. The vast majority are a bunch of experienced operators, and I’m sure many will be happy to help where they can.
Of course, stations calling CQ from VK/ZL will attract many callers in EU, such as operators from other programmes, and DXers, too. They may not necessarily understand what S2S means and why such contacts are particularly important to us.
In those situations, the activator’s best option might be to work them quickly and carry on. The last thing we should do is get annoyed or worked up about it. It’s a hobby, after all, and it’s supposed to be fun!
73 and good luck!
Roman
I shouldn’t tempt providence but…
WX for Edinburgh area at 0600Z on Saturday. Will be 2C +/- however.
I also like to take part, but the weather on Saturday morning looks pretty wet here…
Let’s see. If it rains I probably drive with the car to a local POTA spot with an open view towards the west.
If it doesen’t rain I’ll ride my e-bike to my local summit HB/SO-015 and setup my quarter-wave vertical with 16 ground mounted radials and maybe my compact EFHW. The EFHW-coupler will be for QRO, since I plan to use my FT-891 set to 80 W.
Not sure if I’m doing this right but for GW to VK1:
LP on 20m for 0700z is saying 65%, rising to 85% at 0800z:
SP is showing 95% for 0700z, but dropping to 75% at 0800z:
So is it likely that signals will go short path rather than long path initially? Or maybe both at the same time?
Seems good for summit to summits in any case.
Are you not tempted by an Arthur’s Seat to Arthurs Seat S2S?
The weather forecast for DM/BW-018… and the surrounding region… I won’t be active in these conditions… :face_with_raised_eyebrow: – but perhaps the weather will change a bit.
No. One is a 15minute drive and 5minute walk. The other is a 55-60minute drive and 20-25minute walk. But there’ll be traffic jams on the way and nowhere to park and I need to arrange permission from the Royal dudes. Then even at that time it will be crawling with tourists who will do their best impression of the Tower Of Babel by shouting into their phones in a billion languages ā€œHi it’s me! You’ll never guess where I’m calling from.ā€ before wandering to the Royal Mile to have their wallets raped by the tat shops.
OK, I’ve taken my cynics medicine now :wink:
Had had the idea of participating. Unfortunately, wx doesnā€˜t look favorable here. So enjoy, all!
Vy 73, Markus
I have stopped using the VOACAP dial as I have found that actual propagation at QRP power levels is not reflected in those dials. Higher power, maybe. As a general rule, from Central/Northern Europe it’s long-path propagation to VK/ZL around our dawn, not short path. That’s not to say that short path can’t happen at that time; however, it is rare.
My wife and I are heading off for a two-night stay at the cozy ā€œMalka Buzludzhaā€ mountain hut. For tomorrow, October 17, 2026, I plan to participate in the
VK&ZL S2S Event and the LZ S2S Party by activating the
LZ/CB-018 Karadzhova Kula (1512m), located within LZFF-0679 & POTA BG-0202 (Central Balkan Buffer).
If possible, I will also activate (on Sunday morning) the TOTA panoramic site LZR-0007 Buzludzha,from LZFF-0679 & POTA BG-0202 (Central Balkan Buffer),as well as the GMA/LZMA summit LZM/SP-004 Hadzhi Dimitar (Buzludzha) (1440m), situated within LZFF-0022 & POTA BG-0008 (Bulgarka National Park) .
ALT-512, up tp 10 W, Inv. V, 7m pole, 7-28MHZ, CW & SSB, 145.450&433.500 FM (handy).
73 44 de LZ2AF /P
Around the world, several hams have been collecting NCDXF beacon data for years, using a program called FAROS, written by Alex VE3NEA, and present that data on a website. This way we get a wonderful insight in radio propagation on the 20-, 17-, 15-, 12- and 10-meter bands. Besides signal-to-noise ratio data, FAROS also collects long path / short path data, based on the delay with which signals are received. PA3EWG is a local Dutch ham who has been collecting NCDXF beacon using FAROS since 2011 (so over 1 complete solar cycle!). You can view the data at https://monitorstation.ccms-best.nl .
In order to make scrolling through the dates easier, I have created a small web app at https://www.qrd.nl/radio/faros_viewer.html that displays PA3EWG’s data in an easier fashion. Switch to ā€œPath plotsā€ and look for the yellow dots to see the long path propagation; the blue dots are all short path propagation. Scroll back to see recent days, or a year or a solar cycle back.
As you can see, October 4th, 2026 and the week leading up to that date had quite good propagation from VK towards EU in the UTC mornings. And without exception it was always LP propagation…
I wish us all good LP propagation tomorrow!
73 de Frank PA4N
The contacts are basically made via the long path. The short path has more attenuation due to the skips over land, while the long path crosses only oceans.
My plan is to operate mainly on 14 MHz, both CW and SSB. I’ll also try the higher bands, but I’m not counting on much there. I think I’ll use a butterfly delta loop, with an EFHW as a backup in case I have trouble setting it up.
It’ll be quite chilly, so I hope I remember to bring a beanie and gloves… Good luck to everyone, and have fun!
Hi Frank, I have a technical question about graph: can we assume that the presence of short-path signals does not rule out the presence of long-path signals as well? Alternatively, can the signals highlighted in yellow also include short-path signals? In the case of two paths, is a specific color assigned?
Thanks
Hi Frank,
I had not heard of FAROS, I will certainly take a look at it; it sounds like it could be a very useful tool.
Thanks for creating the web app also.
Good luck for tomorrow and the S2S action. I will need to take a small detour as a road has been closed, but I hope to be on air by 0630 UTC.
73 Ed DD5LP
I’ve just been running through the gear I’ll have. KX2+ PA + ATU-100, 2x batteries. I was just checking I had all the bits for my DD5LP Ed-tenna and realised I was short of a set of radials, now made. Interested in trying it… I should have done that before but I know the single telescopic works so we shall see how the ā€œdirectional-omniā€ works out.
Must check I have the lengths and spacings are noted down and which way is LP to VK/ZL.
Good luck to all of you tomorrow! :four_leaf_clover:
I am on I/SI at the moment with a group. I was able to make a spontaneous first activation of I/SI-170 before using my bike, while the others where having breakfast :blush:
Now we are heading to Catania. Sadly there is no chance to be on a summit tomorrow morning.
