“Where has thy been since I worked thee?” Well if that was one of my first contacts from Hoove with a new FT817ND some 2892 days ago (7 yrs 11 months….) I have been activating all the NP summits, and the last one Rombalds Moor (Ilkley Moor) yesterday, a bit pathetic really as Anna Wells managed all the Munroes in winter in 83 days not nearly eight years, however I did have a job and am still Dad’s Taxi service….
Health Warning - Moderate to low levels of excitement likely to be sleep inducing. Does not contain descriptions of epic adventures involving activations by boat, just slightly damp feet at times….
Rombalds Moor G/NP-028
The hardest part of the activation was the driving as it is the NP hill furthest from home. Radio wise it was a bit of a struggle. I started on 10m which seemed worryingly quiet - 0 QSOs. I thought it would be easy on 2m having a good view of a large urban area, but I don’t know if it was the time but initially just 3 QSOs - one in Lincolnshire so the kit was working- perhaps everyone else was still in Blackpool. Then I tried 40m which seemed a bit long earlier in the day and no response to my spotted CQ so finally activated by calling a bunkers on the air station on 40 with a weak report. Not quite the grant pile up finalle I had anticipated…… Finished with a nice rag chew on 2m. To summarise, short level walk, watch the sat nav directions and a nice view. Perhaps it was being dogless- no barking auditable in the CQ call….?
Favourite Hill
Wild Boar Fell G/NP-007
This is a hill that looks like it is a mountain and the path is reasonably dry. Not only that but the summit is both huge and quiet with enough space for several antenna farms. And the only hill where I have experienced a Brocken Spectre…
Toughest Walks (A draw)
Mickle Fell G/NP-002 and Cross Fell G/NP-001 (From Garrigill). Mickle Fell was longish and wet requiring a pre arranged permit, so despite only being 13 km return it felt longer. Cross Fell from Garrigill was longer (25Km return) , the following day Woody struggled to get up for a wee! I am probably stupid as I have used the route from Garrigill before and afterwards always thought it was a long way and I wouldn’t repeat it, only to decide that as as I was now older it probably wouldn’t feel like such a long walk. It did. ! (Take a bike or go from the West…)
Best Small Hill
Dufton Pike G/NP-027
A mini Matterhorn with brilliant views and a pleasant walk usually with good car parking. Only 1 point but well worth it!
Wettest Hill
Aye Gill Pike G/NP-023
Perhaps it was just the day I walked it, but there seemed to be a lot of soup near the summit and lots of very boggy bits. Not one on the repeat list!
Easiest Points
Burnhope Seat G/NP-003
OK it is a very short drive from home, but the road is only 150m below the height of the summit, and with a carefully chosen route it is quite possible to reach the summit without a boot full of water. Plenty of room for antennas and the trig point (Which is fairly infrequently visited) still has a hole in the top which supports a mast. My first transatlantic QSO from a summit (Using G6XX callsign)
Busiest Hill
Whenside G/NP-004
A mighty hill with some amazing railway engineering to walk underneath, but from Ribblehead very busy. The AZ is a reasonable size allowing some space to set up away from the summit. Probably best early in the morning!
Most Photogenic Hill
Nine Standards Rigg G/NP-018
I don’t think anyone knows for sure who built the Standards or why they are there, but in the snow they are very impressive!
Best of the Rest
The Calf (G/NP-013) combined with Yarlside (G/NP-019)
The (Steep) walk up Cautley Spout is more like a Lake District Hill, but the round tops of the Howgills remind you it isn’t quite the lakes. Not too busy and the climb up the side of Yarlside will definitely get the circulation going! No pints at the pub as it is a Temperance Inn!
Equipment
I started with a FT817ND and a SLAB. I seemed to struggle to qualify the summits so added a linear to get to about 30w… Following a memory issue (I forgot the battery which given the weight should have been obvious…) I then got an FT-270 to add a second rig for 2m FM. As I got older I noticed the weight, the first change was swopping the SLAB for lithium batteries, and the biggest change was getting a KX2 which I now run off its internal battery with no issues. For an antenna I use a linked dipole, the longer one (80/60/40) working well at the quiet end of the sunspot cycle and the current one (40/20/10) . (I tried an efhw but still prefer the dipole) For 2m I have a ladder line J Pole, both on top of a 6m mast. I have also added a Tarp (DD Tarps super lightweight and a collapsable pole for wet summits). Logging - Rite in the rain paper logs, HAMRS used to transcribe it, and MacLoggerDX on the Mac. (As part of my retirement present to me I decided that I had more than enough of Windows so I have different bugs to explore on the Mac. On Windows I used the excellent Log4OM)
Thoughts…
Everyone climbing hills will have their own opinions about what is “good” and why and the weather makes a huge difference, so these are just my opinions. As I am now retired this probably qualifies me to feel Older and Wiser, but as in the Pink Floyd lyrics the truth (particularly on a summit) is …
“And I’m feeling the cold
Thinking that we’re getting older and wiser
When we’re just getting old”
- Paul
