Hi folks,
DMR2SOTA is a new gateway to send spots from Brandmeister DMR network (more than 5.000 repeaters WW) to Sotawatch.
Instructions:
Send an SMS to the private id 214996 as the following example (use spaces to separate fields):
EA2/VI-001 14.205 SSB EA2CQ/P Optional_comments
You can use the wildcard ‘*’ on callsign to announce yourself:
EA2/VI-001 14.205 SSB * Optional_comments
or
EA2/VI-001 14.205 SSB */P Optional_comments
After sending, you will receive a succesful or fail SMS depending on Sotawatch answer. If it gives error, you must check the format of your SMS.
Other available commands: (similar to commands APRS2SOTA)
/SPOTS or /S : To receive the last 3 spots published on Sotawatch
/LAST or /L: To receive the last spot published on Sotawatch
/ALERTS or /A : To receive the last 3 alerts
/INFO summit_ref or /I summit_ref: to receive info about the requested summit_ref (eg: /INFO EA2/VI-001)
/TIME or /T: To receive UTC time
/HELP or /H: For help
Special thanks to:
Andrew VK3ARR for the support with Sotawatch connection.
Mikel EA2CW for testing the gateway
73 de Iñigo EA2CQ
