Monte Perdido - Three days in the mountain
Monte Perdido EA2/HU-003 - Three days in the mountain
Day 1
The adventure started in Gavarnie, where we left the car behind and set off towards the high mountains. The first part of the hike took us up towards the Refuge des Espuguettes. Through the surrounding peaks, the first glimpses of the Brèche de Roland appeared, giving us a taste of what was waiting higher up.
Brèche de Roland from Espuguettes
I had vaguely planned to climb the Piméné on the way, but by the time we reached this part of the route, it was clear that we were already too late to fit it in. So we carried on towards the Brèche de Tuquerouye instead.
Hourquette d'Alans, going to Tuquerouye
The climb is always a spectacular one, and once over the pass, the whole landscape suddenly changes. Mont Perdu and the Cylindre rise above the Lac Glacé, dominating the valley in an almost unreal setting. This was to be our home for the night, and we settled down for a bivouac beside the lake.
From the Brèche itself, were the little refuge was full for the night
Mont perdu from Lac Glacé
Day 2
The second day started with the climb towards Mont Perdu. We crossed what remains of the glacier, and I have to admit that it was a slightly heartbreaking sight. I’ve been here a few times in the past twenty years, and the glacier was a completely different thing back then. Seeing how much it has retreated since is hard to ignore. The old photograph really puts the change into perspective.
The Glacier in the 1900s
Brèche de Tuquerouye, where the refuge is right in that V over the lake, a very peculiar one.
From the Étang Glacé, the final climb towards the summit is not particularly difficult, although the scree makes it fairly physical. Once on top, I quickly set up the ‘SOTA performer’ and made the activation, sticking to 20 metres only. The views were excellent, although the atmosphere was a little hazy, taking away some of the clarity I had hoped for.
Final ascent, from Etang Glacé
Views from the top of Monte Perdido
After the activation, we descended and then headed back up towards the Marboré, at 3251 m, where we planned to spend the night. Carrying four litres of water and a litre of redwine per person from the Étang made the climb considerably more serious than it would otherwise have been. It was hard work, but the reward was worth it. Up there, the views are simply incredible, the kind of scenery that somehow never comes across properly in a photograph.
Cylindre and Monte Perdido in the back
Gavarnie - Pic du Taillon
And then came one of those simple mountain moments that make all the effort worthwhile: spending the night under the stars, above 3000 metres, with nothing around but the mountains and the sky.
The rain in the horizon was quickly replaced by a clear sky for us
Day 3
After a slightly windy night, looking at the stars rather than sleeping, sheltered in our stone circle, the sunset was welcome.
Lac Glacé, Tuquerouye, from the top of Marboré
The third day was mostly about the long journey back down. We took the opportunity to explore the Casteret Cave before continuing towards the famous Brèche de Roland.
After crossing the Brèche, the descent towards Gavarnie seemed to go on forever but the scenery remained spectacular all the way down. And apparently, we weren’t the only ones enjoying the views. This marmot seemed to have a pretty good opinion of the place too.
Cirque de Gavarnie - World Heritage Site
Three days, two summits, a glacier that has changed dramatically, a couple of spectacular bivouacs, and a SOTA activation at 3350 m, a pretty good way to spend a few days in the Pyrenees.
Espectacular, !!enhorabuena!!
Great report and photos. The peaks are very rugged and dramatic. Also, looks like a real bivouac. I always take an ultralight tent on multi day treks for warmth and for rain. But you had great weather.
Bonjour Rémy,
C’est magnifique! Bravo et merci de ce partage.
Juste une question: Pourquoi ne pas passer un peu plus de temps à faire des QSO?
Sur un sommet, 5 minutes de trafic pour 6 QSO et sur l’autre 8 minutes seulement.
Le 20m n’est pas la bande idéale, le 40m serait plus adapté.
Les chasseurs qui ont vu ton alerte la veille sont surement frustrés.
Personellement, je n’ai pas de station au QRA, donc je ne chasse pas, mais quand il m’arriv(ait) d’activer un sommet rare et exceptionnel, je voulais absolument en faire profiter un max de chasseurs. Exemple F/AB-001 en 2016 (1 heure sur 40m-cw).
Maintenant je randonne avec un copain, qui n’est pas radio, et très rapidement il me demande d’arreter mes transmissions au bout de 30 minutes! sur ce je m’execute. hi hi
Continue de nous partager tes aventures. Merci
Gerald F6HBI
Yes we only bivy like that when we know the weather is ok. Having only the sky above your head at 3000m is a great feeling. The tent is cozy but you are blind …
Merci Gerald !
Effectivement ce n’est pas beaucoup de temps derrière la radio, mes excuses pour les chasseurs qui ont loupé le spot. Malheureusement ce n’est pas toujours évident de rester longtemps. Au pic de la Géla, je pouvais tout juste tenir debout a cause du vent, alors j’ai du me mettre en contrebas dans les rochers, en tenant l’antenne d’une main, le micro + le smartphone de l’autre !
Au Mont perdu, j’étais avec quelqu’un et on avait prévu d’autres sommets notamment pour aller bivouaquer. Passer 1h derrière la radio n’est pas vraiment possible dans ces conditions. Du coup je me met sur une fréquence et je vais au bout de la pileup. Ensuite j’appelle encore 2-3 min, si ya personne je coupe…
Sur 40m j’ai eu très peu de contacts lors des dernières tentatives alors c’est vrai je vais pour la facilité sur 20m seulement.
Ceci dit , je vais essayer de faire un effort et de proposer 40m quand c’est possible :grinning_face:
Il faudrait aussi que je regarde s’il est possible de mettre a jour une alerte via Garmin inreach, afin de préciser l’heure exacte 1h avant par exemple. Car poster une alerte depuis la maison deux jours avant et être dans l’impossibilité de la modifier (pas de réseau pendant 72h …) c’est un peu frustrant.
Des vues fantastiques, merci pour ces belles photos Rémy. Ca fait très envie!
73, Peter
Can we have some kind of warning before you post so many stunning mountain images please! :slight_smile:
Really is very impressive.
Nice marmot.
Hi Remy,
Again, your reports and photos are truly inspiring.
I was happy to hear your callsign during our trip to Sotllo, Baborte and Pedres Blanques this weekend (you contacted Juanjo on 40m on each one of them), but we missed you on la Pica d’Estats!
Winter is coming. I’m eager to know what you have in mind for this season.
Best 73!
Yes I was so excited to chase you guys on your trip ! I’m so sad I missed the pica d’estat, I was out on the tractor and missed the notification… it would have been my first complete !
I couldn’t hear you on 20m of course, 40m was my only option. Well done for that trip Alberto !
Beautiful!!
Thanks for sharing with us.
Amazing scenery and a tough trek, Rémy!
Thanks for sharing the adventure with us.
73, Marcial EA2WX
