Midweek Quickie on Tinto
WX was going to be blue sky non-stop and I was going to drive out to Luss to continue bagging uniques. But I had a few chores to do this morning so I couldn’t do Luss and the chores, the chores won and so Tinto won a quickie activation.
It takes about as long to drive to Tinto as Scald Law so it may become my longer training hill. It’s 3.4km and 470m ascent so somewhat more than Tinto. Also the final pull is a bit steep and it does grind when you want to play on the bands!
Anyway parked up and booted, at the top 1hr30 later including a few longish talks to other walkers. I parked by a 911 Carrera 4 GTS which has a lovely shine. I was de-booting when its owner arrived and we talked Petrolhead / Midlife crisis cars and supported each other about the cost of tyres for cars that go a bit…his are 1.75 times more than mine and mine make me cry when I buy new ones.
So Tinto… at the top I decided to play with the 41ft “random” this time. I’m using my IC-705 to get more used to using it so out it came, up went the 41ft and off we went. Well I would have but I couldn’t get a match on 15m. Booger! This has never happened before but I have never set the 41ft up using a fence before and I wonder if the fence wires were doing bad things. Never mind a match was easily found on 17m and 18 QSOs worked on CW with ODX being 4Z4DX. I couldn’t get a match on 10m either, again never happened before but 12m was easy and 2 CW QSOs worked there. 40m matched easily an 5 SSB QSOs worked, 40 seemed quiet but I worked Tom M1EYP/P, long time since we had an S2S. I realised I’d never tried my 705 on 60m and I have loads of 60m stuff in the memories so onto FE I think (5.3985 USB) and Paul G4IPB was an easy QSO then Tom appeared, a bit quiet at 41 but workable. I finished on 30m CW and worked Tom again, he was louder on 30m than 60m. I also worked Victor GI4ONL on 30m. I’ve been working lots of short skip G QSOs during the current maximum, quite novel in some ways.
After that, a Toffee Crisp, a long drink, packup and comfort break and back down to the car ASAP. Took about 50mins but more chats on the way. The WX was wonderful, very few clouds, a bit hazy, warm in the sun, amazing blue sky and a damn biting cold wind.
OK, so I need to play with the 41ft to find out why it was not matching today. I am getting to like my 705 more as I use it, CW sounds better with athe 150Hz filter but some people are not in the passband when they call. Luckily the waterfall shows them and a quick RITing and there they are :slight_smile:
IC-705 is strong sunshine, very readable.
I was fed up that I was missing out on the head mounted SOTA antennas…Ed @DD5LP has a head mount whip he uses. Tome @M1EYP has a head mounted AlexLoop. So now I have a head mounted 5m pole with 41ft Random :smile:
The view out towards Culter Fell, Gathersnow Hill and Broad Law. Broad Law is visible centre righ in the far distance. Behind me is Edinburgh/Glasgow and all the Central Belt towns, the most densely populated part of Scotland and in front of me is an awful lot of nothing that looks nice.
Possibly the largest Bronze Age (2000BC-700BC) Cairn in Scotland at the summit along with a 50’s vintage trig point. The moss growing on the trig nicely hides the graffiti that assorted Scheme Goblins painted on it 20 years back. And yes, that sky is really that colour, it was causing lots of people to check their GPS in case they had been transported down to The Med!
Antenna system. 41ft random wire running about 4m up the pole then out to a distant fence post. 3 counterpoises (as suggested by Heinz HB9BCB). My camera again shows its huge dynamic range, yes the white/yellow blob is the Sun… it does appear in Scotland sometimes :slight_smile:
38 QSOs in 1hr15 on the air midweek will do for me. A damn fine leg stretch and I had a chocolate bar, I wasn’t sure if the exercise was enough but a blood sugar reading of 5.5 when I got back was just peachy. :peach: It’s a work day tomorrow… boo!
Looks like a fun time! Saw your spots when I got up this morning - no copy here!
I looked at RBN and I was being copied on the East coast and inland a bit. 5500km distant stations WB6BEE, 4dB (he’s not in W6-land I think), K1RA, 5dB on 12m and VE3EID copied me 5dB on 17m. Maybe playing with the sloping section direction and counterpoises would have lifted those signals. Probably another 1hr/2hr later and it would have been a go-er into W7 land.
The more I think about the better this quick session was for a mid-week.
I can’t decide which Teletubby you’re trying to look like :wink:
Going with Dipsy
Haven’t you seen the Liverpool FC Bobble Hat ? Mrs. FMF was trying to knit a bobble hat for my son but she said she need to practice as she couldn’t remember the exact “recipe”. So I said “knit me an LFC hat.”
This what appeared and when I saw it I said “That’s MUFC not LFC colours and I’ll look like Dipsy when I wear it!” She did offer to redo it in the correct colours and to remove the Dipsy appendage but I wear it for special occasions. Such as this on The Fara GM/WS-106.
Thanks for the contact on 60 it makes a change at this stage of the solar cycle. I’ve been doing some lazy chasing, the main home antenna is a doublet (200 ft) between trees which I normally match with a manual ATU to the 7300 that can cope with the load, but recently I’ve just started connecting the KX3 and letting it do the work and… it appears that 10w works well for chasing. PS Tinto is on my list of hills to activate but it is a 2 hr drive (at my speed). PPS No 1 daughter starts at uni but has chosen the East Midlands and not too many summits on the Nottinghamshire Alps …….(Not Aberstwyth or Edinburgh which would have been a better SOTA excuse)
After all your trips to CT3 I am surprised this wasn’t in your bag
Can we get SOTA branded versions?
If you pay for me to go there (and return) to collect some :joy:
Is that cut to length for 70cm ?
What Barry doesn’t show is that you need a tin-foil hat to capacitively couple it to your head or it wont work.
Actually I tried to get this one of me with a tin-foil hat as my ID card picture but it was rejected not for the tin-foil hat but the lighting was poor. No sense of fun our security people.
:rofl:
Get one of these. It will protect your ears.
From someone who had a melanoma removed from an ear lobe 15 years ago and now never wears a baseball cap.
But then, you don’t have enough sun to cause a problem, perhaps?
