Nice one Patrick!
I built a K3NG keyer in UK Lockdown #1, sadly it hasn’t seen any use yet.
I built my keyer using an Arduino Nano and a proto board.
VY 73 and good luck with the project.
Colin
Nice one Patrick!
Colin
Nice build also Colin,
Are you satisfied with these tiny pushbuttons ?
How high is the shaft ?
73,Patrick
The push buttons are described as 7mm but that’s the total height. I think the shaft height is about 4mm.
I bought the buttons for my KD1JV MTR rigs. I have a dodgy button on my MTR-5B, it’s a bit intermittent. The fault hasn’t got bad enough for me to strip the rig down yet.
My MTRs have proved to be very reliable but I keep switches in stock, just in case.
The buttons work just fine on my keyer, although there’s not much shaft sticking up through the holes in the case. The case I used was a cheap extruded aluminium enclosure which I purchased via Ebay and was shipped from Hong Kong. The metal is quite thick.
73, Colin
Yesterday I finally wanted to activate my “minimal art trx”. (my lockdown project)
My 40m endfed worked well in the garden and on Friday evening I still had 2 qso’s.
I made a pilgrimage to DM/BW-115 and felt like a little kid before Christmas. I had everything set up and heard good signals.
Unfortunately, I didn’t got any HF in the air. I didn’t have any measuring equipment with me and checked everything again and again - but couldn’t find the fault. After 2 hours I broke off quite frozen and went home again.
At home, the TRX worked perfectly again… (GRRRMMBBBLE)
Murphy law !!
Good luck finding the issue Armin. I’m sure it will be something simple.
Better luck next time.
73, Colin
I still have a QCX in its box with original packaging still unmade. from January 2018. Thinking I might just keep it as a collectable lol, as I’m not sure I’ll get round to it. I might one day. Its a 30m version BTW.
Anthony
Hi Armin, did you discover what the problem was then. Interested in your dilemma .
73 de Geoff vk3sq
I found a loose contact on a coil in the transmitter… and I hope that was it.
I pull such thin wires through a drop of solder on the soldering iron and burn away the lacquer with it and scrape it off. I think I didn’t got it all when I removed the protective lacquer. ![]()
Of course, I want to get it back on a summit as soon as possible.
The kit has been a nice start to get back into tinkering. My next lockdown project is the qcx mini for 30m - starting at Easter. ![]()
Hallo
Today was the day.
The beautiful weather of the last few days has thawed away the snow even above 1000m asl in many areas.
On DM/BW-018 there are benches, tables and a fence to attach the telescopic mast.
There I made myself comfortable with the MA 12.
After self-inflicted initial difficulties, it went quite well
Tnx to the chasers - Armin
Well, the PCB fairy has been today and delivered my self-designed data mode cable boards from JLCPCB and they’re superb. Made one up and it works great. No more larger-sized prototype stripboard and glue. I’ll have to find a small little plastic box to put this in to protect it from the elements. Board is around 4cm by 4cm and it’s made for a TRRS jack.
Edit: wrote it up here - Shitty Amateur Electronics - Part 15: Data Mode Radio/PC Interface
With laptop for size comparison:
All soldered up, minus the optocoupler/serial part as I need to order the IC, so the hard-switch is used instead. I definitely didn’t catch the transformer with my soldering iron…:
Couldn’t resist this my lockdown project - well it is sort of relevant as the TX is on 13cm
and the name reflects the activity
No longer a lockdown project, but I was inspired by Armins’ @DL6GCA post above, about his ZM-4 ATU, so this is my version of the Z-match ATU.
I tried to copy the design as cheaply as I could, and it works !
I just mounted everything “in the air”.
I did not implement the 160m option, since I had no need for that band.
The chassis is made of pieces of PCB, and I still have to make the cover, also from PCB material, and put some labels on the controls.
I tested it with my SOTA endfed (9.15m + 9:1 UNUN) ,hanging indoors from the attic to the ground floor (kitchen table), and I could tune it everywhere from 80m to 20m. Higher bands not tested yet, but I suppose it will work there as well.
Why did I need this tuner ?
I wanted to use my new QDX (@G0UPL) with such a temporary random wire, and I had read that the QDX doesn’t like bad SWR.
So I don’t want to be one of those “smoke signal” senders … hi.
Luc ON7DQ
I finally found time to complete above project, and put some more info on my blog.
Enjoy!
Luc ON7DQ
Another small project that was inspired by the work of “super tinkerer” Colin @M1BUU …
I didn’t want to build a Rockmite, but I had a few PIC chips like those that are used for the keyer in that rig.
So I extracted only what is needed to make a very simple iambic keyer, and put it in a cassette box.
It can key any small QRP rig, and adds a sidetone, so it may be useful for Pixies and the like. Or even just to check if your paddle is still working.
See picture and circuit info on my blog.
Luc ON7DQ
