JA SOTA QSO Party will take place on 17 September 2022 from 20:00 to 18 September 2022 at 09:00 (UTC).
Core time is 00:00 - 03:00 (UTC) on 18 September 2020.
De Katsu JP3DGT
De Katsu JP3DGT
Thank you Katsu-san.
I will qrv from summit, hope to see you on the air.
JG1BOK/Matt
I hope it’s as fun as it was in Spring! When I have decided the summit, I will publish it in the alert
73, JP3PPL
I hope to get out in the afternoon to participate from OR. Rodeo weekend but hope to squueze it in for some s2s! de AG7GP
I’ll attend JA SOTA QSO PARTY.
Hope to log in a lot of QSO, incl. DX & S2S!
Cu & 73,
de JG0AWE / Hiro WAKA
I hope to make it out on SOTA that day.
I need a good chance to work my summit number 400.
Hope to make S2S with you guys.
Regards
Ian vk5cz …
Last week I was chased 3 times by JH1MXV during my activations when I was on lowland summits in HB/AI and HB/SG. It was in the time between 10 and 12 UTC …2 x 14 MHz and 1 x 18 MHz in CW.
I had 5 W on an Inv.-V Endfed …
The RST were between 339 and 559 with QSB
I think that I will be on a Summit on Sunday from 0600 UTC.
Hello,
I’d like to participate, weather and duties permitting.
In the previous JA SOTA party I had a S2S with JA, at the end of the event (around 07:00 utc) on 14 MHz Long path.
I hope to have the chance to repeat it this time.
In the core time (00 - 03 utc) there should be little DX chances, I guess.
Good luck all, 73 Ignacio
Hola Ignacio.
El horario central de 00:00-03:00 UTC es para incentivar a los locales ya que son las 09:00-12:00 horas local. Y con Europa el horario con mayor posibilidades se da entre las 07:00 y 09:00 UTC o sea 16:00 y 18:00 local.
En el evento anterior olvidé el cargador de la batería y no pude activar para trabajar europeos. Espero que esta vez haya revancha y que en tu caso puedas repetir y mejorar tu experiencia!
73 de JP3PPL, Takeo
Thanks Takeo, yes, I see the event is long enough to work your local friends plus to get a chance for the DX!
Sure we all will get a nice experience in your party.
Your spanish is very good, muchas gracias, un abrazo
73 de Ignacio
Takeo speak spanish better than me, hihi. Cheers!
I hope I will wake up morning and try yo get a S2S to JA.
Because I was born in Buenos Aires…
Abrazo!
the decision has been made…
I will be active on 18 September from 0600 UTC as DL20SOTA/P from DM/BW-003.
I have an Endfed that I can connect to my small MX-P50 PA at 40/20/15/10m… for the other bands I plug the antenna directly into the KX2 and use the tuner.
I hope for my first S2S with JA
Now only the weather has to cooperate ![]()
I put the Alert on SW3 for JA SOTA QSO PARTY 2022 AUTUMN.
Subject to change depending on WX.
See you On The Air
Can’t wait for JA SOTA QSO PARTY 2022 AUTUMN!
We’ll activate JA/NN-204 (kurofu-yama) .
Hope the weather is fine that day.
JG1EJY es JG1EKA
Hi JG1EJY Naoki-san,
Maybe It’s easy to QSO with you from JA/NN-075 = S2S.
See You On The Air!
de JG0AWE / WAKA
New Antenna system, 20m & 15m HWEF with trap has been finished.
Also hardware to stand up the Spider Beam 10m Pole and etc. 3D printing finished last night.
Hope to see you on the air.
de JG1BOK / Matt
Today’s shack
Hello,
I participated activating EA2/NV-092.
Going very early in the morning is rewarded with a nice sunrise
Working conditions were a 9m long wire with 4 ground radials of 4,5 meter, plus the ZM-2 manual tuner. I installed it on a vertical 9m fishpole. Rig KX3 10w.
Running first in 14 MHz I logged some nice DX from ZL and VK but JA signals were very low at the beginning, and I could not work the stations I saw on spots. At that time in the morning I heard some of the chasers with a strong echo, as their signals were received simultaneously via SP and LP, with a delay. As the sun started to go high in the sky, Short Path improved in 18 and 21 MHz.
I began to hear clear signals from JA and got the call from JR8MHA/P for a good S2S from JA/MG-091, thanks dear Katsu!!
Afterwards I heard readable signals from others like JA5QJX/0, JI3BAP/3 or JP3DGT/3 (it seems his pole broke and he dissapear before I could call him!).
I got a few calls from weak stations I couldn’t decode and later had some more EU S2S in my log.
Although the day started with 11º Celsius, it wasn’t windy and had fun.
Thanks for the event and see you next time.
では、また
73 Ignacio
