Thanks Toru!
Quite surprised by the good conditions on 15 meters!
Pete
WA7JTM
Thanks Toru!
Pete
WA7JTM
Thank you for this great initiative and thank you to all the activators for the many contacts. To redo as soon as possible…! Chris - F4WBN
I’ve just set up on G/SP-015 and hoping to catch some of the late action!
Chris, thanks for the QSO. Your signals weren’t from this Planet!! 599++
73 de JP3PPL
I don’t think Chris suffers from ‘skip’ or other propagation difficulties that affect mere mortal radio amateurs! Always a good signal here.
Glad the event went well.
Ah, the difference a big antenna farm can make…
Here, with my little sapling of a hexbeam, JA SOTA CW signals were on the edge of workability, almost, but not quite…
(Also, I was probably up a little too early, and then fell asleep again before the propagation picked up.)
Toru-san,
Thank you for 4 QSO’s across 2 UTC dates. The only JA station I worked on 3 bands.
Regards & 73!
Andrei, de ZL1TM
Chris, Thanks for your 2 calls. You are always very strong and amazing.
Toru K JA1CTV
S2SのQSOを有難うございました!
Hi Andrei,
Thanks a lot. Appreciate always. It was very stable signals through out today from you and got many NA, EU, OC and AS stations. Wish to see you soon mate.
Toru K JA1CTV
I don`t remember very well but I think I was chased by Chris 3 or 4 times during very early morning activation (approximately 2100UTC) and during this time his signals always were stronger than the ¨normal¨ time (0800 UTC)
The same with DJ5AV, also his signals were 599+
Take san
Thanks for your call today, I got many S2S just in a day. From now will count them.
Toru K JA1CTV
Thank you! When I called you my battery was running flat… luckily we did it!
73 de JP3PPL
Ian
Yap, 15m was very good today. Thanks for your call, always appreciate.
Toru K JA1CTV
Dear JA friends, thanks for organizing this event.
I went to activate EA2/NV-092. I woke up early and arrived in the summit at 06:00 utc.
Weather was miserable with light rain.
I struggled to setup the antenna: big mast (9 m) and difficulties to put it up against the wind, but after 40 minutes I started the rig.
Equipment: KX-3, 10 watt. Batt: Lipo 4S plus diode V reducer. Antenna: Vertical EFHW.
I focused on 14 MHz.
I worked first some EU stations, and after 15 minutes I got a call from JH1MXV, thanks Hatori!
It seems this opened the Long path window and I then worked @VK2IO, @VK1DA, @ZL1TM, @ZL1BQD and @VK5CZ. That was great!
Afterwards I tried to hear some of the activators running on 14 CW, and I succesfully heard @JP3DGT Katsu, @JI3BAP Aki, @JA5QJX Yasu and @JS1UEH Takeshi.
Some of them were barelly readable and others better. I called some of them unsuccesfully, as I think my power was lower to their.
I had better luck with Aki JI3BAP/P who was kind and requested AGN several times until he got my callsign right! I am very glad to log my first JA S2S.
I heard many EU ops succesfully logging the JA ops. At the end I tried 18 and 21 MHz a bit but signals were much lower for me.
Operating today was unpleasant. I worked half an hour holding my umbrella with one hand while operating with the other: nasty!
At the beginning my aerial was dangling around with the wind and that changed my calling frequency inadvertedly untill I was conscious I had lost my pile up!
Certainly it was not the best day for Portable, but these precious DX made it worthwile.
I’m looking to try next year with a better setup.
Thank all and see you soon.
忘れられない一日をありがとうございました
73 de Ignacio EA2BD
Hello friends,
As I had little time for QRV today, I headed for the easiest summit in AKITA prefecture.
This is JA/AT-135, about 100m from the parking area !
It was cold and windy though…
Thank you for calling me,folks.
Atsu
Hello, SOTA Friends!
I had lots of fun yesterday on Flint Peak, W6/CT-225. My setup was a KX3 running 5 watts and two antennas; a 66’ doublet and a 15 meter half square, both fed with a single CAT5 twisted pair. A 30’ Spiderbeam pole supported one end of each antenna and the other ends were tied to a fence around the comms facility.
I was ready to operate around 21Z and started with a couple of US S2S. Then I was delighted to hear and work Takeo, JP3PPL/3 on 15 meters. A few minutes later I heard Christian, F4WBN, calling JP3DGT/3. Katsu was not copiable, but we managed a QSO later on 17 meters. Hideo (?), JH1MXV, a regular chaser, called in on 15 meters. Yuki, JF1NDT/1, had a good signal on 12 meters and we quickly completed an S2S. 20 meters was disappointing. I never heard any stations spotted there well enough to try calling.
In total I had 12 S2S with Japanese stations. 12 and 10 meters will be great S2S bands soon.
Conditions on Flint Peak were warm and sunny to start. As the afternoon progressed a storm was approaching so the wind picked up and the temperature dropped. My half square vertical elements are very light and blow around easily. I wonder how the pattern changes as the elements move. I packed up before sunset.
Thank you for organizing the event. It was a pleasure to participate!
72, David N6AN
I was able to receive some weak signals from JA activators on CW on 20m and 17m. Nothing heard on other bands or modes. Didn’t manage to make a S2S into JA - but my log did include a ZL, so that in itself was satisfying.
Hope this becomes a regular event.
Quick summary of JA SOTA Day
JA station SOTA Watch Spots : 448
Spotted summits : 57
Spotted callsign : 56
There are non-spotted operations then the numbers are more.
My results
Total QSO : 152
Total S2S QSO numbers : 35
Pointed S2S QSO numbers : 34
Total S2S points : 135
It was really fun and the results are best record for me in terms of QSO numbers and S2S numbers.
Thanks all.
Toru K JA1CTV / JH0CJH
Hi Tom,
I listened for you while you worked ZL1BQD but heard nothing of you here in vk2. I was hearing EA and DL stations well. Worked EA2BD and heard EA4R and EA2LU. Some odd propagation happening there.
I also heard some W callers but didn’t see a spot or cq for them so no chance to chase them.
73 Andrew VK1DA/VK2UH
