Do you still remember your first time?
Sade sings: It’s never as good as the first time…
With my experience today: I can’t really agree with that…
When I started to itch again in 2018 after almost 20 years of abstinence from amateur radio (you never quite get rid of this virus), I visited the HAM RADIO in Friedrichshafen. There I somehow came into contact with SOTA and knew immediately that this could be something for me… especially as I am otherwise very outdoorsy.
My possibilities to set up a shack at home are extremely limited. My antenna is a wire from the balcony to a tree… and as a transceiver I have an IC 703. Surprisingly, CW was like riding a bicycle. You quickly get back into it…even if it didn’t run so smoothly at the beginning…and so I managed a qso from home every now and then.
On the summit it should be even better. I wanted to test it and activated my first summit.
It was clear: it had to be an activation on short wave in CW. But how and where?
I could only use the equipment I had. A large hiking rucksack, IC 703, an unfortunately somewhat heavier 12 V battery, the antenna was a 16.5 m long 2.5 mm bronze wire fed via a fat 1:9 Unun, a Daiwa cross pointer SWR meter for control… and of course my Bencher BY-1 morse key. Everything was carefully packed.
When I set off, I felt like I had set off on an expedition.
Fortunately, I had chosen a more comfortable peak, DM/BW-055, where there are tables and benches.
Fortunately, there were no visitors on the Summit that morning. I threw a string over a branch and pulled up the antenna wire. Everything was assembled, working and I had a first qso. EW4DW called CQ and I answered… it wasn’t really SOTA yet but more a /P activity on my part.
Then I ventured into SOTA and called @HB9CBR /P on HB/VD-016… Bruno was my first SOTA contact … later I dared to call CQ SOTA. After 3 hours I had 18 qso in the log. With my excitement it was not always easy for the qso partners…
But when I went back in the early afternoon, I was happy and knew SOTA is for me!
How was your first time?
