I managed to plan a couple of days away with my friend Mark, tagging along as he completed his last few Munros. The plan was he would do GM/SI-005, Blaven on Monday alone, I had already done that plus I was doing CW Field Day over weekend so could not get up to Skye before Monday evening. Tuesday we do GM/SI-004 Sgurr nan Gillean plus Am Basteir and Bruach na Frithe at the northern end of the Cuillin Ridge on Skye. Then Wednesday down to Loch Quoich to do summits on South side by kayak.
Mark is an active climber, where I am best described as competent but rusty. By rusty I mean 25 years of rust!!! I do enjoy scrambling, fairly fit and no issues with a bit of exposure. We settled on this route - up Bealach a’Bhasteir, then up and back down the west ridge of Sgurr nan Gillean, then Am Basteir finally Bruach na Frithe decending into Fionn Choire. Weather was great, dry with a bit of cloud and pretty calm.
On way up, looking back to Sligachan where we started.
Sgurr nan Gillean’s pinnacles on the left, Am Basteir + Basteir Tooth on right. Follow the scree between the two peaks.
Almost at the top of the scree in Bealach a’Bhasteir
Fast forward and we are at the top of Sgurr nan Gillean! Am Basteir front right, Bruach na Frithe high peak behind. Phone was stowed when I put my gear on. Went up Tooth Groove & Arete, fine but a bit exposed…
Me going through the hole on West Ridge
Mark below at the hole
Rest of the Cuillin Ridge
Guide with his clients on Tooth Chimney below
Mark waiting for the party below to clear the abseil
Me coming down Tooth Chimney
Then up and down Am Basteir’s east ridge, before dropping to right of Am Basteir and climbing up Bruach na Frithe
Sgurr nan Gillean from Am Basteir
Sgurr nan Gillean and Am Basteir from Bruach na Frithe
It was a quick activation with KX2 and 6m wire, 22 qso’s on 30m and 20m. 15 minutes and was packing up again. Really great day out, cant wait to get back to Skye.
Sadly the plan for Loch Quoich by kayak scrapped due to wind and rain, Mark went to do Gairich alone via the dam. I had already activated it (and remembered the bog!) so I activated Ben Tee in the rain.
73 Gavin
GM0GAV
