Very true on general rules taking precedence, and thanks for sharing additional info. In the main rules section for activators, I was a little surprised the 25m does not seem as firm as I originally thought (activator section rule quote below) and mentions “typically 25m”. Other ARMS were more clear about “must be within 25m”, “82 feet”, etc.
“The Operating Position must be within the Activation Zone. The operating position
must lie within a closed contour line at the permitted maximum Vertical Distance
below the summit. (Typically the contour line is 25 metres below peak height of the
summit). The Operating Position is taken to be the position of the operator”
The earlier summit rules section is more clear, saying normally will be 25m…and other than 25m, “the AM must provide a justifiable case…”
“…Accordingly, each Association shall define the Vertical Distance from
the precise summit, within which a Summit operation will be considered valid. This Vertical
Distance will define a contour outlining an Activation Zone within which a Summit operation
will be considered valid. This Vertical Distance will normally be 25 metres. For other than
25m the AM must provide a justifiable case and also the MT may review this at any time,
based on experience.”
Thanks again… 73
