EFHW Build - High SWR on 15, 12 & 10
Hi,
I’m not the most practical person in the world but decided to have a go at building an EFHW transformer. I looked at lots of threads here, and opted for a single FT140-43 with 21 turns in total and 3 on the primary. I’ve done my windings as tightly as I can, and also added a 100pf TDK capacitor.
I’m at the testing stage, so added a 2K, and 470Ohm resister in series between the antenna port and the ground of the SO239. The resistors are Metal Film (Is that OK?)
SWR on 10,14 & 17 are great, but at 15 it starts to creep up, and at 10m it’s around 2.5 or 2.6. The scale on the VNA is 7MHz to 29.7MHz.
I did read (again here) that spreading out the secondary windings might help, but that seems to make the situation worse.
Any tips of tricks much appreciated.
Peter M0LMG
That seems like an odd combination of bands. Usually the low SWR should be a multiple of the lowest frequency e.g. a 20m long wire should work on 7 MHz, 14 MHz, 21 MHz and 28 MHz.
Your SWR plot definitely looks wrong - it should be should be high with dips at certain frequencies, something like the one on this post:
SWR does tend to creep up on the higher frequencies but the capacitor is supposed to help with that (on mine it doesn’t make much difference).
Is the wire you used on the transformer enamelled? (insulated from the core and adjacent turns)
Are both bits of the twisted part connected to the ground? One looks disconnected, but it might be the photo angle.
Thanks for the reply,
Yes, the wire is insulated, and both ends of the twist are connected to the ground.
I know the normal SWR plot of an EFHW, but I believe its different when you are using a resistor, because its fixed.
Peter
With just some resistors that mikic and endfed how should this be resonant?
Build looks fine. Add the typical 20,1 m of wire and cut so that you are reaonant on 7,1 MHz or easier to see at about 14.2 MHz and the other matching bands 15 and 10 will be kinda okay. 17 or 12 will not work without a tuner or some tricks (or traps)
Here’s mine with a 2K7 resistor:
SWR is about 1.5:1 for most of HF.
And here’s how it looks inside:
Mine’s a different core but still 43 material. It’s a 14:2 autotransformer.
Read the OP again. It’s with a resistor, not a piece of wire.
Thanks G4TGJ,
I will try 14:2. I think I read that 21:3 was better with smaller cores, but that may well be wrong.
Peter
Hi Peter,
This is caused by the 100pF capacitor, at 30MHz, its impedance is about 53ohm, so the whole EFHW transformer becomes 25ohm, SWR reading of 2.5 or 2.6 is not far off from the theory.
This doesn’t mean you should remove it, because in the field, it’s not easy to get a perfect 2470ohm either.
Wei AG6AQ
Hi Wei,
Thanks for the reply. I tried removing the capacitor, but it didn’t seem to make any difference.
Best wishes
Peter
I do it since 2013 this way, added 100pF and it worked for over 20.000 qso.
Thanks DLC1R,
There serm to be a few similar designs, but I’ve not seen one with 16 turns before. I will be sure to give them all a try.
Peter
You’re only going to get an SWR reading that’s valid for the resistor you placed between the two poles.
A wire antenna is going to present different impedances based on the frequency, so the values will change over the course of the band sweep.
Take it out into the yard, and cut a wire for 40m on the freq you will use, and it will resonate on 40, 20, and 15. You’ll see the SWR dips on your VNA and can trim the wire for the band.
With a tuner, you can use the non-resonant freqs. Without a tuner, you’ll be good on the 40-20-15, and not-good on the other bands.
Using a random wire length and a tuner, you can use 80-10 quite easily.
But G4TGJ posted his VNA images earlier with a 2.7k resistor and it was level across the HF frequencies.
Connect a 50Ohm resistor to the VNA and sweep that. Is it flat?
You have done the short, open and load calibrations ?
Here is a link to this topic from a few years ago
Also Youtuber MM0opx has videos on testing various transformer cores efficiency. You may wish to look into that. 73 es GL
Can you confirm the winding is right ? From the picture, I don’t understand why you have a twist because I count only 3 turns on a single wire for the primary.
If you go for the twisting method (the transformer) you should have 3 turns of twisted pair, not 3 turns of a single wire. If that makes sense.
If you go for the continuous single wire (auto-transformer) you should’t have any twist in the setup. One continuous wire with 21 turns and just one bit of wire “taped” (= soldered) after the 3rd turn to the center of coax.
Good morning,
I just found I could quote, so sorry everyone for the earlier replies! Yes, I calibrate each time.
Indeed, he does great videos.
Good morning,
Yes, I studied the two normal methods, but the method I used was linked on a SOTABeams page:
If you watch from 3 minutes, 25 seconds.
I will try the ‘normal’ method later this week, and just cut a wire (once the weather improves), and give it a go.
You have your windings out of phase to other examples.
I followed the video I linked to above, but will try the other methods too. Thanks
