Data base logging/submitting error
On the sota database I’ve just tried upload an activation. Entered manually on my iPhone
When I get to “submit log “ and press “submit” I get a box with red letters, “. [object Object]”
And nothing is uploading.
I can’t see any faults or errors in my logging.
Any help please?
Most of the time it is a typo or bad formating in date/time or summit reference fields (it needs to be written in capital letters).
Also some phones add a blank/space char at the end of an entry. That might also cause this issue.
Hope that helps.
Tks Joe
I will try and have ago at removing spaces - a tedious task as you can’t see them.
But less daunting than having to re-enter 50 plus QSOs. :flushed_face:
Joe.
I discovered I’d left a callsign box blank!!!
You saved me a lot of work - thank you very much.
David
