Last Thursday I saw a little chance for my first SOTA outing this year on Friday. I charged the battery. Friday late forenoon an appointment was canceled and so doing SOTA was possible. Quickly I grabbed the SOTA boxes and two poles and went out.
I had two goals, testing my new build high band QMX with a new antenna configuration on the first summit and looking for DX from the second.
On DM/TH-004 I took my EFHW (9.x m long), used sometimes before vertical, wound slightly around a 10 m pole, now mounted horizontal. The transformer end was fixed with 3 m string to my backpack on the ground
and the other end to the tip of a 5 m CAPERLAN fishing pole standing behind the branch of a tree.
It’s a quick deployment. The wire was optimised for the old configuration. I was curious about the SWR for the new configuration.
After switching on the QMX I saw a frequency in the 80 m band! ??? Oh, I grabbed the low band QMX. Ok, also good for 20 m. (This was my first error but not the single one). Checking the SWR (nice feature of the QMX) and … the next surprise – a value a bit below 4. So much effect from the different deployment? But I was after my schedule. Lets check this later at home. The match was done by the ATU and lets start calling. RBN found me (7 skimmer from 600 km to 1100 km, as I saw at home) during my first CQ. 15 QSO came in the log in the next 29 minutes. I was surprised about W2WC on 20 m.
Disassembling the station I’ve found this.
Aaaargh, how stupid. I didn’t connect the antenna wire to the terminal (second error this day but one more was waiting). But 15 QSO and one W!? I guess 3 m koax, 3 m counterpoise, the station and myself were acting as an antenna. Should I bring antenna wire on summits anymore? Following a rough calculation maybe around 10 mW could reached the antenna via the tiny capacity from the wire to the terminal. After connecting the wire a last test brought a SWR of around 1.6, ok.
Next destination DM/TH-064 is a convenient summit with bench and a restaurant on the top, luckily reopened some months ago. Without the high band QMX I had to use my backup FT817 for 10 m. I opened the antenna box to get my 6 m vertical but … not there!?! Last year I added some guying material and had to put the vertical in a small extra bag. Because of the hurry before starting from home this bag was forgotten (third error). But folding back the 9.x m wire to half made a EFHW for 28 MHz. Mounted vertical at the longer pole and span the counterpoise horizontal and elevated transformed this more to a FW dipole.
My first CQ was picked by a scimmer only 20 km away! In the next 11 minutes I could work five US-stations in CW. Changing to SSB added one more US and two ZS5!
All in all a good outcome despite the errors. A big coffee and a piece of cake in the restaurant completed this special SOTA tour.
Thanks a lot to the chasers
S57S ; EA2DT ; M0RJPp ; G4AFI ; EA7GV ; SP9IDE ; SM5LNE ; S52CU ; SA4BLM ; S58MT ; F8AOF ; OE6GND ; G0HRT ; W2WC ; 2W0ILQ ; @WA7JTM : NT2A ; @KB7HH ; @N4MJ ; @WB8BHN ; @ZS5APT ; @ZS5AYC ; NW4TF
Cu on the band from the next summits.
73 Ludwig
