Pretty much as i thought then! Thanks buddy
Alan
Alan
If you look at the public logs you do see the CRC errors on several igates.
I have been wondering at what point do the Lora igates start causing problems for each other, if a lot of igates are sending APRS objects to RF, and then those objects also get digipeated. In a busy area that could be a lot of traffic.
I wonder if that point is now being reached producing CRC errors for multiple igates.
I think turning off sending APRS objects to RF will significantly reduce Lora traffic.
But thatâs just me pondering
Yes I have been thinking about this too. My iGate does TX objects and messages to RF, but I have a 20km filter on it to try and reduce the noise. But even then I wonder whether itâs actually of any use to anyone else? I could just as well set it to RX only and just upload to APRS-ISâŚ
There has even been an interesting discussion locally here in WB about how frequently trackers are beaconing and potentially jamming up the frequency and causing collisions. The default smart beacon settings in the tracker softwares are quite âchattyâ⌠Maybe in an area with no other trackers it doesnât matter, but down here there are quite a few in regular daily use in cars.
APRS filters are going to become more important I think for Lora igates. Itâs a nice problem to have though with proliferation of Lora igates
I suppose the filtering an igate uses depends on the traffic in your area.
Coverage is still fairly sparse in GW/NW land so less of a problem.
And if they include âWIDE1-1â in their Path, they may trigger several digipeats after each beacon. That may be useful in remote areas, but from the slopes of Winter Hill there are now 18 IGates within direct range, so digipeating certainly isnât needed.
