Beaver Ponds and Blackflies, a North Ontario activation
North Bay in Ontario is a small city just where the Southern Ontario (VE3/SO) and Northeastern Ontario (VE3/NE) SOTA associations meet. The terrain is gently rolling hills covered in mixed deciduous forest, (maple, linden, oak, birch, poplar and such) just south of where the vegetation changes to that of the great boreal forest that stretches over 5,000 km across northern Canada.
I lived in North Bay for several years, and still visit the area. At the end of May, 2019, I was able to activate NE-485, one of hundreds of un-named, un-activated summits in the NE area. I took advantage of an electrical transmission line that runs close to the summit of NE-485, about 4 km from the small village of Ferronia. Travel along the right-of-way is easy. It is a wide cut-line through the bush. However a small stream runs down each valley, and it is not unusual to find that beavers have dammed the stream, requiring a detour through the bush to get by.
Beaver pond on the way to the summit of VE3/NE-485
On this particular activation, there was a good steady breeze blowing along the right-of-way, but when I turned into the bush for the final 300 metres to the summit, the blackflies rose to cover me! I had forgotten just how vicious these small, biting flies are. I had also forgotten my insect repellant! I hurridly put on my rain jacket pulling the cuffs and hood as close as I could. I lasted 20 minutes on the summit, making just 2 SSB contacts on 20m before abandoning the activation! Afterwards I was able to count over 40 bites on just my hands from the 20 minute activation.
Blackfly beseiged SOTA activator
Indeed the blackflies have such a reputation in Canada that they were the subject of an animated cartoon made in 1991 by the National Film Board of Canada, which was nominated for an Academy award!
https://www.nfb.ca/film/blackfly/
Happy activating.
Ian VE6IXD
Having canoed in Northern Ontario a few times before becoming an amateur I would have thought that many of the hills could be accessed by canoe? Is that so?
Hello David,
Yes, indeed, I am aware of a number of the higher summits that are accessible by canoe. For example
Ishpatina Ridge (VE3/NE-001) and Maple Mountain (VE3/NE-011) are a couple of peaks I have visited in pre-SOTA days.
A couple of good sources of information about canoeing and hiking in the Temagami area are Temagami - Ottertooth.com and
http://www.nastawgantrails.org/
Close by is the town of Cobalt, a historic silver mining camp.
It’s an interesting area, well-worth a visit.
Ian
VE6IXD
Wow. Maybe worse than Scottish midges… Black Flies in the Backwoods of Ontario - YouTube
It can be pretty bad for bugs there. Old Army issue bug juice was formulated for that area. Over 90% DEET in it. It would melt your compass in an hour if exposed.
Unless needed I would never venture where Ian was until early Aug, but had to at times for work.
Malen
VE6VID
