I’d spent several evenings pouring over the new SOTA summits map, searching for suitable summits I could activate in my annual winter trip to Scotland before the winter bonus points stopped. . A trip which until I started SOTA was one focused on on winter climbing/mountaineering/hillwalking and x-country skiing. This would be my 2nd trip to Scotland where my objective would be activating and anything else would take second place. But I took my ice axes, crampons and skis just in case!
So off I went in our newly purchased second-hand camper. Moffat being on the way and having a few worthwhile SOTA summits along Moffat dale, this became my 1st stop. Then headed up to Arrochar on the west coast, followed by a stop in Glencoe to nab the only 10+3 of the trip. (GM/WS-017). A slight thaw in the weather made the snow hard going so I headed across to the Cairngorms to finish off my trip on firmer snow…
(a) (b) (c) (d)*
29 Feb 2020 MM6GYU/P GM/SS-082 (Capel Fell) 8– 2,-- 3, 114
1 Mar 2020 MM6GYU/P GM/SS-100 (Croft Head) 13– 2,-- 3, 119
3 Mar 2020 MM6GYU/P GM/SS-142 (Scaw’d Fell) 11– 2,-- 3, 124
4 Mar 2020 MM6GYU/P GM/SS-122 (The Wiss) 1 7- 2,-- 3, 129
4 Mar 2020 MM6GYU/P GM/SS-141 (Beinn Ghlas) 10– 2,-- 3, 134
5 Mar 2020 MM6GYU/P GM/SS-016 (Beinn Narnain) 16– 6,-- 3, 143
6 Mar 2020 MM6GYU/P GM/WS-017 (Meall a’Bhuiridh)11– 10,-- 3, 156
8 Mar 2020 MM6GYU/P GM/ES-010 (Bynack More) 15– 8,-- 3, 167
9 Mar 2020 MM6GYU/P GM/ES-036 (Geallaig Hill) 15– 4,-- 3, 174
10 Mar 2020 MM6GYU/P GM/ES-050 (The Coyles of Muick) 17– 2,-- 3, 179
( !st column = QSOs, 2nd = points, 3rd = bonus points, 4th = my accumulitive points.)
10 summits in total. 133 QSO’s all morse/cw. Plus a handful of S2S. Few of these summits had mobile signal so I relied totally on the RBN or once or twice being spotted by other chasers. I had intended to activate more than one summit on one day but I ended up only doing this the once.
I used 10mhz mainly and stayed on air until until there were no more callers -
I did QSY once but altering the links often resulted in me getting rather cold and it was sometimes difficult to re-arrange the inside of my bivvi bag without knocking equipment about.! .
(Below = Slab avalanche on the approach to Capel Hill, Southern Highlands)
Equipment taken/used on the hill:-
- HB1-1B MkIII
- 2amp SLAB battery*
- Small morse key
- SOTA beams linked dipole
- Telescopic pole
- Norwegian collapsable snow shovel (For digging snow shelters)
- Small two man Bivvi shelter (with a sewn in section to sit on and prevent it being blown off. This proved absolutely superb - My wife bought me it several years ago but until SOTA dawned I’d not needed it - indeed I’d forgotten all about it until some weeks ago
- Ipad, + antique iphone 4, but neither used other than taking photos with.
- A5 log book, A4 clipboard with callsigns + names of regular chasers. (It seemed a nice thing to greet callers with their names when they use mine.)
- Fingerless gloves with a ‘pullover’ mitt - another new purchase which proved excellent . I also carried a pair of simple goretex overmitts which made a great combination. (Gloves from Jack Pyke and only £6.00!)
- Map, & compass
- Spare gloves
- Waterproofs, Spare thin duvet jacket
- I don’t often take food or drink into the hills but took some fruit most days.
- Bungee cord & 16” length of drain pipe, the pipe which is just the right size to allow my pole to fit inside. Driven in the ground, hard snow or supported by rocks makes an excellent support for the aerial on bare soil or peat and I never had to use any guys, even in winds of 25 knots or over. I guess you call it a drive in and pull out stake!
That lot weighed in at around 15 lb - 20 lb, somewhat lighter than a rucksack full of climbing
kit
(Below = a snow hole in which I also used my bivvi shelter ).
- The SLAB Battery has now been retired thanks to G4OBK selling me a 2amp LiPo battery pack he had spare. Thanks Phil.
On two summits I had bad qrm on 10116 and a few khz either side - this was a loud buzzing/drilling sort of noise. I was within a mile or less of one transmitting mast once but the second time I was well over three miles from any mast I could see.
(Below = Inside my green caterpillar/bivvi shelter, callsign crib & log book)
My radio gave me a couple of panic moments when it insisted on showing “SSB” when I’d tuned it to the CW segment of 10mhz and once when it showed “TX error” and showed no power output. Both cases were remedied by either switching it off and on or simply fiddling with the Memory button. The radio is carried in a waterproof box. When being used its taken out - perhaps damp could be an issue? Do radios suffer from the cold?
(Below = A fine summit cairn on the Coyles of Muick)
SOTA has introduced me to a totally different Scotland and one I’ve really never taken much interest in before as many of these summits have little attraction for the winter climber/skier.
A number of the these smaller hills are fine summits in their own right.
(Below = the long lonely road home - heading towards the Glen Shee)
David Perry M6GYU
Robin Hood’s Bay.
