I am planning to activate 8 days long as many SOTA summits as possible in Teneriffa (EA8/TF) over the period of 30.10 to 06.11.2023
I will operating VHF FM around 145.500 and also 10m -(12m - 15m) - 20m - 40m SSB (5W).
I’m post each day on the reflector the following planned summits.
Also u can add me on SOTA Spotter with the callsign EA8/IN3JIB/P.
I’m also open for hints, information about Teneriffa
Thanks for preparing the mountains for Teneriffa for more SOTA activities.
I will take over from the 4th of November on and will stay for 2 weeks and will try to activate more of less every summit. Teide most likely not as I was too late for a permit.
My plan is also to activate every summit but in 8 days its not that easy.
You can activate Teide after 6pm and if u wanna make it official you can get your permit here. Don’t forget your headlight
Would be awesome if we meet by a beer or on an activation.
Okay that is good news that it is possible at a later time. Will need to bring warm cloth and a headlamp. Thanks for the hint. I see an adventure with some 10m DX in the evening coming up
I will arrive on the 4th in the late afternoon. So 5th would be the only option I guess.
Sounds like a plan
Yes you normally need a permit to go on top of Teide if the cable car is running. i did the activation last year when the cable car was not running due to wind. We did all the way up then without cablecar. It was a very beautifull hike up in this wonderfull landscape. And the wind was as well not really a problem except the last few hundert meters to the top. There it was sometimes quite tricky to continue and that was the reason that my activation was quite short.
And this island is most beautifull at about 1000m upwards
