Activation #533 took place on Shining Tor G/SP-004 this morning. It hadn’t snowed overnight and the roads were clear up to the Cat & Fiddle. A few patches along the ascent were a little slippery, but otherwise a pleasant if cold early walk. A little light snow fell throughout the ascent.
Setting up the 12m/10m GP was tricky as the ground was frozen hard. Fortunately there was very little wind so I could get away with relatively weak pegging points.
The temperature boost experienced by getting inside the bothy bag was most welcome. This comes with a “health warning” though - but more of that later.
I received a weak CQ from a G station in IO91 on 12m FT8, but that station vanished before I had chance to call. Both 10m and 12m were otherwise completely dead - as anticipated at this very early hour - so I went onto 2m FM for the time being.
Six stations were worked on 2, following which I tried again on 12m FT8. This time two stations were worked. The band was again empty, but there now appeared to be activity on 10m. As I listened though, I heard that most unwelcome but recognisable sound - the swell of static noise - snow static in this case!
I could hear the light snow continuing to patter against the bothy bag, but I didn’t lift the bag to actually take a look. It was nearly time for a low angle pass of the ISS so I switched to MMSSTV to try and RX another image.
I started to hear the signal from the ISS, and my tablet began to decode in PD120 mode. But then a very weird noise and lots of flickering and blacking out on the tablet screen. The noise was identified as the G4ZLP MiniProSC interface rapidly switching itself on and off. I tried to switch it off and disconnect without making contact, but I accidentally did and got a shock from it. I insulated my hands with my dry fleece as I tried to disconnect the FT817, but got shocks through the fabric anyway.
Only one thing for it - lay the aerial on the ground, carefully dismantle the gear, and abandon the activation.
When I emerged from the bothy bag, I found to my shock (a different kind of shock) that the “patter of light snow” was, in fact, heavy snow that had dumped about 8 inches on the ground in the last hour! And that is the health warning with bothy bags - they can give you the warmth, dry and comfort, but with it a false sense of security and a potentially dangerous lack of awareness of the outside conditions.
It was hard to pack all the gear up without it getting wet in now very heavy snow. Even harder - to the point of impossibility - was collapsing the SOTA Pole, which was frozen solid. I had to attach it to my rucksack at full 7m length to carry it down to the car.
Once I was back at the parking spot, the A537 had vanished under the snow. I wondered if I was going to be able to safely drive down to Macclesfield. The bottom few sections of the pole would now collapse, but the upper sections were still frozen. I could now - just - get the pole into my car, between the boot door and the front windscreen!
The drive down to Macc was mainly in second gear at 20mph. The road was fully whited out until the canal bridge, well into the town. A lorry and several cars got into trouble between the top of town and Walker Barn blocking the road for eastbound traffic.
After my ordeal camping out on Shining Tor on the night of that huge storm in August, I think we can now officially describe G/SP-004 as a shocking summit!
