Activation #534 of 2020 was a night operation on The Cloud G/SP-015.
The intention was to use both 2m and 6m, with both antennas (SB5 beam & SB6 Moxon) assembled prior to 8pm, ready for a speedy changeover from one to the other when required.
After a tricky ascent to the summit on hard, compacted, smooth and slippery ice, I realised i’d failed to pack the boom extension for the 2m 5-element beam! Instead, I used what i had to cobble together a 3-el beam. This comprised the director and reflector from the 5-el beam, and the two shorter pieces that make up the driven element.
The issue now was that i had no proper insulation between each side of the driven element. In a moment of ridiculously over-optimistic madness, I balanced these two rods so that they were only marginally inserted into the holes on the boom, but not touching each other inside the boom. I had to arrange the feeder cable so that it applied some strain on the elements, just to stop them falling out of the boom! To my complete and utter astonishment, this all worked!
2m FT8: 18 QSOs - EI, G, GI
6m FT8: 12 QSOs - 9A, G, GM, HA
It was a spectacular night on The Cloud. The summit was coated in a crisp layer of snow, which was reflecting the bright moonlight from a full moon. The earlier fog moved off the summit and sank into the surrounding valleys, creating an inversion effect. Under the bright moonlight, this offered a rather unique and mysterious visual spectacle.
Oh but it was so cold! I was quite pleased with myself, and in fact somewhat surprised, that i stuck it out for the full 2.5 hours of the contest.
