Wind & LiPo power
Thanks for all the calls today.
The antenna was a 21m long half wave end fed vertical held up by a Cody box kite. No advantage at this time of year, but its fun and much lighter than a fishing pole.
The DC power was supplied by a 5ah LiPo battery pack, which happily ran the IC7000 at full 100w+ output for the duration of the activation.
The LiPo pack is 600g, so its a lot lighter than equivalent SLABs. However it does require some voltage reduction, as the peak charged voltage is approx 16.8v. I do this with some bridge rectifier diodes in series and gradually remove them as the voltage drops. (Does anyone knows how to design light weight DC-DC converters that can handle 20A ?)
Overall its a nice combination if the wind is consistent.
Regards,
Nigel. G6SFP/P
In reply to G6SFP:
Well done Nigel… I’ve always fancied trying a kite antenna. Shame I was in the salt mine.
Where did you manage to fly that? The field next to the trig?
…and I assume the gliders weren’t around and turning low over the hill? :slight_smile:
73 Marc G0AZS
In reply to G0AZS:
By the Go Ape climbing area.
The kite will fly with little wind, but with todays wind the problem was actually getting it down again.
Nigel.
