Spots not appearing?
I attempted to generate a spot at 0700 for HA5CW, which was accepted but not displayed.
I repeated the spot but still nothing.
Roy
G4SSH
In reply to G4SSH:
Hi Roy, I just tried a test spot and it was OK.
Mike
In reply to G4SSH:
Hi Roy,
I also just tried & the spot appeared correctly.
Mark G0VOF
In reply to G0VOF:
Thanks, Mike and Mark
I will check out my system, although my first repy to Mike was not accepted
Now test spotted without problem, maybe a temporary glitch (0727z)
73 Roy
In reply to G4SSH:
GM dear OM
I spot HA5CW/P no result
I spot OK2BMA/P it is OK
73 Daniel
In reply to F5SQA:
I spotted HA5CW/P as G4OBK and then edited spot to read HA5CW/P and you can see the result.
73 Phil
In reply to G4OBK:
OK PHil but no good for read
HI
Daniel
It seems that HA5CW has his name in the database as:
Jozsef (“Joska”)
Its the quotes that are causing the spots page to be broken.
Stewart G0LGS
In reply to G0LGS:
Sorry for the problem. Yes, it is the quotes that are causing the problem. I have temporarilly fixed this by removing the quotes. I will seek to fix the code when I get some time to do so.
73, Jon
