Hi All
Does anybody know of a map showing the general location of SOTA peaks? I travel around a lot whilst working and am pretty sure I could have activated peaks had I known I was near to them. A large scale map showing location/google earth/GPS list etc would be useful for those spur of the moment activations. Any help appreciated.
(going to London from Yorkshire tomorrow via the M1 if anybody can suggest anything??).
Cheers
Tim
In reply to G4YTD:
“Marilyns”
Richard
G3CWI
In reply to G4YTD:
For google Earth summits.kml is in the files section on here:
http://www.summitsbase.org.uk/
Nigel. G6SFP.
In reply to G4YTD:
Cheers
Tim
Bardon Hill G/CE-004 not far off motorway.
http://www.sotawatch.org/summits.php?summit=G/CE-004
As for maps there is a file in the old reflector files section with all summits to display on google earth.
Roger G4OWG
In reply to G4YTD:
If you have a satnav, there is a file showing parking places for all G and GW summits plus several Scottish ones at:
http://www.sotabeams.co.uk/cards.htm
Scroll down the page.
This is used by a great many activators.
Richard
G3CWI
In reply to G4YTD:
You can download waypoint files for all the Marilyns (and many other summit lists) for all the popular mapping programmes from
http://www.haroldstreet.org.uk/
The following formats are available: GPSU, OziExplorer, MagWay, DataSave, Gartrip, Anquet, Google Earth and GPX.
Thanks All
Just fighting with the POI file now to convert it to Garmin. Its looking good for bardon Hill on the way home tomorrow!
cheers all
Tim
G4YTD
In reply to G4YTD:
There used to be a mainland UK route-finding map with the SOTA summits marked and colour coded for points in the files section of the old SOTA site. Does anybody know if it is still accessible anywhere? It was very useful.
In reply to G8ADD:
Hello forgot your callsign or name as using a pda here. if you traveling up or down the m1. then why not activae the summit at junction 22. park up at mac’donalds and away you go. I believe 20 minutes to the top.
Steve m0sgb
