New Server
Hi,
I have had a brand new dedicated server up and running for 2 or 3 weeks now but have been procrastinating getting it live. Sorry! I just haven’t been sure about how to do it with minimum disruption.
This server has very considerably more capacity in terms of processing power, memory, etc than the current one and you should notice a significant difference.
The new server is currently at http://new.sotawatch.org with an old data set.
I think I will get the data up-to-date and then put a notice on the old one to the effect that the new one should be used. Then I will change the DNS on http://www.sotawatch.org . After about 24/28 hours this will have fully propogated so that ‘www’ will point to the new server and the old one will be cut loose.
I’ll keep this thread up to date as I make the changes.
73, Jon
In reply to GM4ZFZ:
Seems very quick Jon :slight_smile:
But thats perhaps due to the small number of users hi.
Look forward to it going on line.
Roger G4OWG
In reply to GM4ZFZ:
Doing data transfer now. Please don’t post anything!
73, Jon
In reply to GM4ZFZ:
Right, we are live on the new server. I notice I have got error reporting turned on on this server one so you may get a few errors and warnings cropping up. Please notify me of them in this thread and I’ll fix them rather than ignoring them as I have been on the old site :wink:
Now to change the DNS.
73, Jon
In reply to GM4ZFZ:
DNS now changed. This site should be available under www.sotawatch.org within the next 24hrs or so.
73, Jon
In reply to GM4ZFZ:
Hi Jon
Seems to be working much more quickly already! Many thanks for the upgrade.
73 es HNY de Paul G4MD
In reply to GM4ZFZ:
Good job Jon… it’s flying here.
73 Marc GØAZS
In reply to GM4ZFZ:
Truly excellent Jon - there is no comparison to the old set up. This is immeasurably quicker - many thanks for all your hard work.
73 es HNY,
Gerald
In reply to GM4ZFZ:
A minor point, but I notice that we are getting a backslash inserted in front of apostrophes.
#10
Jon,
Well done Jon - Much faster.
However I have noticed that certain characters typed in reflector messages end up with a slash character appearing in front of them.
(i.e " and ')
HNY
Stewart.
#11
In reply to G0LGS:
Hmm. Don’t know why the apostrophes have suddenly become a problem. Must be a subtle change in the configuration. I’ll look into it.
#12
Jon,
Could be something to do with PHP magic quotes.
(http://uk.php.net/magic_quotes)
Stewart
#13
In reply to GM4ZFZ:
I wrote a \ and got two, then edited it and it became four. Weird!
#14
Wow, very fast currently, nice work Jon.
Trying to update user details seem to cause a ‘hiccup’ (still works ok on the ‘old’ system). Is that a DNS issue, in which case it will eventually resolve itself.
Many thanks for all your hard work.
Regards, Mike G4BLH
#15
In reply to G4BLH:
Yep. Magic Quotes it was - thanks Stewart! Turned them off in php.ini and all is fine.
73, Jon
#16
In reply to G4BLH:
Thanks for spotting this Mike.
User details now fixed.
73, Jon
#17
Wow, that was quick.
Many thanks, Mike G4BLH
#18
In reply to GM4ZFZ:
Great job Jon, it seems a lot faster.
Thanks.
73 Mike GW0DSP
#19
In reply to GM4ZFZ:
John, one of my posts on the previous version (New German Summits 19:51) hasn’t moved across, can this be dealt with or is it in limbo?
This works a lot faster, tnx!
#20
In reply to 2E0HJD:
It’s a date problem Mick, try 2008 instead of 2007
Cheers,
Pete
