Also, make sure to fill the field “Callsign YOU used” (don’t know the exact reading) with the correct call, if you have been in a different area (DL/LX1NO/p, for instance, and not just LX1NO)
Most errors/complaints are callsign typos which may occur on both ends.
Always check the log of the activator first (click on “Show All QSOs” on top of the activated references list)
Many thanks to Stewart, Norby and Dan for your helpful info. We SOTA newbies only learn slowly but obviously it is so very easy to enter the incorrect call or summit reference.
I am now down to 2 entries without confirmations.
13/10/07 DL5DXS/P Little I can do unil he submits his logs.
14/10/07 DH8AX/P now changed to DH8DX/P. Sorry Dan.
15/10/07 DJ3AX/P Need to get him to change my call from GM to G. His email is not listed on QRZ.com, so how can I contact him please?
In reply to G4CMQ + others
Just checked my database entries… On one of my activations, I’ve missed a /P off an S to S contact - probably a fairly common mistake… how do I correct this? It looks as if I’ll have to delete the whole activation, and reinput all QSOs… is there an easier way to fix this?
You can download your database entries to disk, delete the erroneous bits on the database and then just upload what you need from the file you downloaded. Sounds harder than it is and you dont have to rekey any data.
Thank you again Dan for getting Lutz/DJ3AX to change my call in his log for 15th October 2007 on DM/TH-830. My log is now back in synch with the exception of 13th October DL5DXS who has not submitted his activator log yet.
