Format of summit lat/long data
I’m vaguely aware of a cunning plan to migrate all summit position data to a single common format. I suspect that the chosen format will be degrees and decimal degrees of latitude and longitude, as currently used in the revised DM Association data. Whilst I can see that such a format is easier for a computer to store and manipulate, it is not a user-friendly system.
In order to look up any summit on a conventional map, or to convert to a Maidenhead locator, one must first make the conversion to “traditional” dd mm ss format. Whilst there are programs and websites allowing this, it is a time consuming process, and one subject to error at each stage.
Is it possible, whilst storing the data in a convenient format, that the “displayed” positional information, on summit search or similar function, is given in a more helpful form? I would suggest dd mm ss N dd mm ss E/W, or Maidenhead locator, or, ideally, both.
Does anybody else have any thoughts on this?
73 de Les, G3VQO
In reply to G3VQO:
Good thinking Les,
I can’t see any problem with displaying the data as you suggest. Once we have all the data migrated, I’ll work on this.
73, Jon
In reply to GM4ZFZ:
Coverting from Lat/Long in its various formats is easy. Converting to Maidenhead locators is fairly easy but… converting between lat/log and UK OSGB NGR is very complicated indeed!
Richard
In reply to G3VQO:
"traditional" dd mm ss format. Whilst there are programs and websites
Converting decimal degrees to degrees/minutes or degrees/minutes/seconds is very easy with pencil and paper. You merely need to know the 6x table and do a bit of trivial addition. If you only want it to the nearest minute its fairly easy mental arithmetic.
One of the huge advantages of storing in a common format is that variant formats for display become easy. Web sites might even be able to offer a choice.
