The server the DB webapp runs on is misbehaving. This means that you will get forcibly logged out after a short time instead of 10mins of inactivity. It also means it is nigh on impossible to submit activations or chases.
Please do not try to log in and submit data until further notice. The hosting company is aware and is working on this. It will speed things up if you don’t try to log in. That gives the host’s staff a chance to view cleaner logs of just their activity without all sorts of other noise appearing.
I’ll say that again, don’t log in till you see a fixed message from me. I’ll have a look at the access logs later to see who was unable to follow this request
Thanks.
Andy, MM0FMF
Database dude (trying to fix this for you, earn a living with recalcitrant customers and have new furniture delivered at the same time.)
[quote=“MM0FMF, post:1, topic:11750”]
[/quote] have a Scaaatch!
Not long ago this afternoon, I logged on to the database and successfully uploaded today’s chaser log. Everything went apparently OK for me, but now that I’ve seen these messages about the issues and asking us not to attempt, I’ll double check later after your fix confirmation message.
73 de Guru
Sorry, but I made several unsuccessful tries today to update my chaser points and then saw your “don’t try it” message. I’ll stand by until I see that it’s OK.
Same to me. I just log on by query from Japan SOTA members, about this malfunction. If this is so important to avoid log on, it need to be announced to association managers. Quite a few peoples are checking this reflector. I will announce in Japan SOTA ML.
Yes - me too. Got it set up to log me in whenever I go to the page from my computer. SORRY. I will stay away from all SOTA until someone tells the North American reflector that it is OK again.
Sorry - I didn’t see your message until after several failed attempts at submitting a log. Thank you for letting us know that there is a problem at your end!
I think I know what the cause of the issue is but it is not yet fixed at 1216Z. So please do not login yet.
Somebody suggested I should stop logins happening until the issue is fixed, the problem with that is that it changes the system. Changing the system may cause the problem to get masked so that I think it is fixed when in fact it isn’t.
I’ve taken some remedial measures but they take time to filter through so the database may well remain broken for at least another 24 hours. Sorry.
