Chasers: Show us your Station
G4OBK - Main equipment of current station in use:
YAESU FTDX5000 (1.8 MHZ - 50 MHZ) (200 WATTS)
ICOM IC-7400 (1.8 - 50 MHZ BACKUP - 144 MHZ CW/SSB) (100 WATTS)
YAESU FT-1802 (145 MHZ FM) (40 WATTS)
DENTRON MT-3000A MANUAL ATU
SIGNALINK USB TERMINAL UNIT FOR DATACOMMS
TWO BENCHER PADDLE KEYS
MICROHAM CW ELECTRONIC WINKEYER
DAIWA CN-801 POWER METER
RADIOSPORT AND SANAKO BOOM MIC HEADSETS
TWO COMPUTERS
TWO SEC 1223 SWITCHED MODE DC PSUs
ANTENNAE:
OCF DIPOLE 160M - 6M MOUNTED IN TREE 40 FEET CENTRE (128 FEET LONG TOP)
7+7 ELEMENT WIMO CROSS YAGI FOR 144/145 MHZ MOUNTED AT 9.5M AGL (DOUBLE FEEDERS)
YAESU G-450C ROTATOR
(ANTENNA UPGRADE IN EARLY 2018 PLANNED - SUBJECT TO PLANNING PERMISSION BEING GRANTED ON APPEAL FOR A MAST)
Show us your station!
73 Phil
Chaser my shack (2e0lkc)
(Deleted the previous post 'cause the picture was upside down)
MTR3B running 2-2.5 watts to a EARC style antenna attached to a fence post about 4’ off the ground. Just set up on a chair out in the garage. Pretty basic.
Patrick AC0SR
respect to all the QRP chasers - that’s the way it should be done!
Chaser shack at M1BUU is pretty basic.
Main shack rig - Yaesu FT817 (2001)
Second rig - KD1JV Designs MTR-5B
Back up rigs - KD1JV MTRs (1st and 2nd batch), Home brew BITX20, SW-40+ and SW-20+
Standard mic on FT817 but with in-line speech processor for SSB.
Keys- RM31 Czech key, Palm Mini Paddle, Kent Twin.
Paper and pencil for logging, Samsung J3(6) for DXcluster / SOTAwatch.
Picnic bench obtained via Facebook advert from maker, £50 several years ago.
Antenna - home brew 5 band 15-40m linked dipole on 9m fishing pole bungee’d to washing line post, ends at about 1.5m agl, running North/South.
Here was the operating position whilst working OK/G4OBK/P during his Czech tour. -
At times I’ve tried CAT control, but it never seems to work out-
When condx allow, it’s fun to chase with my 1watt SW-20+
A non-SOTA QSO, but the following video shows my SSB setup in action.
73, Colin
Now THAT is the way to buy your Hobgoblin! I presume the tray catches any drips…
Hello,
This is my shack today (in constant change, you know…) all fitted in a tiny closet.
TRX:
  • Elecraft KX3 + PA 100w + Tuner MFJ-945E
  • Kenwood TM-G707 for V-UHF
Antennas:
  • Delta loop monoband 40m (homebrew)
  • Dipole monoband 30m (homebrew)
  • Hexbeam 20m–6m
  • V-UHF Vertical Diamond X50
Accesories:
  • Iambic Ariston (old)
  • Rotator Yaesu G450
  • Paper log (backup) + Computer
  • CW Winkeyer USB (contests…)
  • Desk clock (utc!)
It is a pleasure chasing sota friends but I rather prefer my shack on any mountain.
73 de Ignacio
Hete is my rather untidy station. It is in the family office which is used for lesson planning, homework and occasionaly radio.
I also suffer from problems with CAT control…
( Rig Ft450D - MFJ antenna tuner behind it, and an inverted L for 160 and a ZS6BKW ( A rearranged G5RV ) for everything else, all between trees in the neighbouring wood ).
I expected to do 90% activating and 10% chasing - but it does not seemed to have worked that way!
Paul
At the home QTH in the study upstairs …perhaps a messy desk but can quickly clear a path to reach the paddles when activators spotted and heard! Listening on CW with Century in wide open filter position (DC receiver) then responding with KX3 - antenna is 150’ EF-wire at 50’ ponderosa pine trees feed with 9:1unun and 100’ hardline to house.
…Cheers, Steve wGOAT
Boo & Peanut’s view of the house from their goat-yurt
#10
I like to use HDSDR when I’m at home:
Station consists of:
KX3 sn:7060
40-10m End Connected OCFD (from M0RZF)
HF80CL mobile vertical for 80m
PC
Xonar U5 soundcard
Diamond GSV3000 power supply
Alberto Frattini Magnetic Chrome Iambic Morse paddle
Work in progress: adding an common earth bus on the back of the desk.
Next year I hope to add a graphics card that can run a larger 4K monitor. KXPA100.
73 de OE6FEG/M0FEU
Matt
#11
The small keyboards are used portable for CW using the programmed buffer feature of the PX3 and also a KBAR CW device.
Gary a. W0MNA
#12
Latest at mo
More to come up grades etc
Yeasu F450AT
Trio TR-751 2M
MFJ 949D
HOME BREW ANTENNA ROTATORY SYSTEM
F/W 40M LOOP HOZ H/B RG6 Q/STUB FEEDER
T6M 3EL MOXON BEAM H/B
6EL YAGI 2M H/B
CURRENT UNDER CONSTUCTION
160M 1/2W SEXTUPLET FOLDED DIPOLE ( FOR 80M AND 160M)
PLANNING STAGES ALL TO BE H/B
2M THREE EL MOXON
70CM THREE EL MOXON
6 EL 70CM YAGI
VHFUHF SPLITTER BOX REMOTE
Plus various portable antennas and 9:1 and 4:1 UN and Bal.s
Karl M3FEH
#13
AB4PP Station
Elecraft K3S with P3 Pan Adaptor
Antennas
Carolina Windom at 50 feet
Hex Beam at 35 feet
40 Meter Vertical
Heil Pro Set Elite Headset
Paddles
Champion 300 Handkey
Vibroplex Champion Ca. 1968
Mercury Nr 58 by N2DAN
Begali Sculpture
Begali Traveler Lite
#14
Yaesu FTdx1200 100w
Yaesu FT847
Kenwood TS2000
HLA 300 Linear Amp Barely Used On Hex Beam
23cms Home Brew ATV Transmitter
Hex Beam at 35ft On 30Ft Tower
23cms 19 ele Beam for ATV
70Cms 19 ele Beam
6 ele Low Q G4CQM design 2 mtr beam.
On 45ft tower.
Yaesu 650 Rotators
MFJ 993B Intellituner
Tait mobile on 2mtrs FM for aprs or packet with tiny 2.
Heil Proset Headset
Not forgetting the most important asset the wife of 54 yrs who brings in the tea.
#15
Love the AVO 8 on the top shelf :slight_smile:
#16
-Elecraft K3S/100 with most of the upgrades (just don’t have the 2M internal transverter or subreceiver)
-Telepost LP-Pan 2 fed to a 192 KHz external sound card
-Kent paddle key
-Yaesu FT-2900R (these days it rarely has the mic connected. I’m now using it as an APRS iGate/Digipeater, but I’ve made a few local SOTA contacts with it from my QTH to the W4V Shenandoah peaks)
-Dual ViewSonic monitors & a Dell computer
-Software: HRD, Win4K3Suite, APRSIS32 are usually running. I’ve also used PowerSDR IF Stage, and other similar software for interpreting the panadaptor display.
-Astron Power Supply to power the whole mess
-My antennas include a fan dipole for 20 meters and 6 meters in the attic, and a W1AB Killer Antenna fed with 450 ohm window line, which in an undisclosed location somewhere. Incidentally, the W1AB is a solid performer. I’ve made contacts from 160-6 meters with it, DXCC, etc. It’s also very low cost, easy to build, and easy to hide.
Nate N0PCL
#17
EA2LU chaser station:
Elecraft K3+P3
Expert 1K-FA , always half power for EU full power for DX (yes Mariusz no KW here, hihi)
TS 790 for 2M
Old Bencher paddle (gift from 80´s CW students)
Antennas:
X7 yagi for 20/17/15/12/10m
HF2V 160/80/40/30m
Inverted Vee 40/30M
5el vert pol homemade Yagi for 2m
6M7JHV long Yagi for 6m
Living on 5-story building apartment in a city enviroment plenty of human noise, chase is not a easy task!
I want to thanks activators and sometimes chaser for his patience when I twice my calls!!
Starlings like the “magic band” hihi
Sometimes, I chase from my Contest/EME place with OB11-3 and OB2-40 in a 30m high tower, this tower also works in 160m as shunt fed. There also are 2m 70cm EME, tropo antennas. This place is 15km away from home at 750m asl, petrol AC power generator and not noise at all!!
See you on the bands, and thanks you very much for great fun chasing
73s
Jorge
EA2LU
#18
My rig
Yaesu VR5000 HF /VHF/ UHF
Yaesu FRG100 HF
Icom R71 HF
GP5/SSB HF
Yupiteru MVT7100 HF/VHF/UHF
Yaesu FRG 8800
Collins 51J4 & 51S1
Antenna vertical on 4th floor , 8 radials
QTH abt 200m from meditterenian sea shore.
Eyran 4X4-2238
#19
That’s my favourite rx i’m using when i’m on the roof and always impressed of it’s HF abbillities especially on low bands.
Yupiteru MVT 7100
Today btw i’ve reached the 3K points on SOTA SWL Table, hope to aply the award soon.
Eyran 4X4-2238
#20
Past week I sold my qth rig and I am using the qrp for my shack.
#21
That station has worked me countless times! Thanks @G0RQL!!!
Matt G8XYJ
