It shows when I activated this summit, but it does not show when I chased this summit. As far as I can remember on the old webpage both activations and chases were displayed. Is it possible to add this again in the future?
It seems to be intermittent
I tried the page a couple of days ago and it didn’t show my chases,
but when I looked again yesterday it was ok
It’s been like that for a while.
GW0WPO/P on 14 Feb 2019
MW0PLA/P on 05 Jan 2019
GW4VPX/P on 28 Dec 2018
MW0JLA/P on 12 Sep 2018
MW0XOT/P on 21 Aug 2018
First Activated by:
MW0DFA on 18 Jul 2003
Activated by You on:
28 Dec 2018, 09 Mar 2017, 10 Feb 2016, 15 Apr 2015, 26 Jan 2015, 17 Jan 2014, 29 Dec 2013, 06 May 2013 Chased by You on:
12 Sep 2018 - 144MHz, FM
12 Sep 2018 - 5MHz, SSB
21 Aug 2018 - 144MHz, FM
21 Aug 2018 - 70MHz, FM
10 May 2018 - 144MHz, FM
31 Mar 2018 - 144MHz, FM
strange … maybe @G4ZFZ has any idea why it does not show my chases!? is it just me or is anybody else having the same problem?? i chased that summit 17 times:
I normally select Summits at the top of Sotawatch 2,
and then sometimes I can see my chases on say the
G/CE summits.
I just tried again, and although I am permanently logged
into Sotawatch 2, I couldn’t see my chases. Then I noticed that
I was invited to log in to Summits, and having selected this I was
able to see my chases. The password auto filled, so I am not sure
which it was.
I seem to have 3 passwords, 1 for Sotawatch2 which I have used
for many years, 1 for Sota.org, and one for the reflector.
I’ve probably been doing something wrong
My apologies for my very poor understanding of computers.
Hi Ed,
I just tried that, but no good results…
I still don’t see the Chased by you info.
Let’s hope Jon @G4ZFZ can have a look at it and find a solution.
Cheers,
Once you are logged into the SOTA Website ( www.sota.org.uk ), you will be logged in as a callsign which the system will use to try and match your activations and chases. However, it is possible that this callsign (with which you are logged in) is not necessarily the callsign under which you activated/chased.
If you look in your user settings (again on the SOTA Website: Summits on the Air ), there is a field there called ‘Alternative Callsigns’. It might be worth checking if this fields has all the appropriate callsigns you may have operated with and submitted to the Database under.
If after checking that you find you still have a problem, let me know and I’ll take a closer look.
SOTAwatch3 ( https://sotawatch.sota.org.uk/ ) is now fully integrated with the SSO. The plan will be to slowly transfer the dynamic content from the website into SW3 - I have already made a start. The website will then not require a log in, thereby dropping two current logins (SW2 and Website) back into the SSO. We’re getting there slowly but surely!
so far i activated and chased only with my own callsign … but entering my own call in “alternative callsigns” did the trick and now my chases are also displayed!
