With database down, it is not possible to post alerts. I am planning to activate TF/SV-023 around 1100 utc today (25/01/18). This is a 2+3 point summit. I plan to use FT8 at 14.074 MHz. Callsign is TF3EK/P. I expect temperatures below -10 C, so I may not last very long on the summit.
If the computer does not work in the cold, I will try SSB-14.310 MHz
-Einar
Alert TF/SV-023
tf3ek
G7HEM
Oops!
Ignore: “Alerts and spots should still be OK … http://www.sotawatch.org/ seems fine. It’s http://www.sotadata.org.uk/ that’s down, so you won’t be able submit logs at the moment.”
Turns out you can’t post an alert afterall!
Hope the activation goes well.
-Mike
tf3ek
Thanks for the the QSO. It was not as cold as I expected but little more wind. My pole kept collapsing, but I still managed to get 7 QSO
N0MAP
I just looked at Iceland’s SOTA map and drooled. I have never considered traveling primarily for playing radio, but Iceland makes me want to lots. I’ve been wanting to visit for a couple years anyway, but this is just more incentive.
