From Saturday 11th February until Saturday 25th February 2023 I will be on St. Helena (ZD7) together with my wife.
During that time I plan to activate one or more of the following summits:
Diana’s Peak (ZD/SH-001)
White Point (ZD/SH-002)
Flagstaff Hill (ZD/SH-003)
The Haystack (ZD/SH-004)
During the activations my call sign will be ZD7MG/p and I will be active in CW - as always.
I will use a KX2 (10 W max.) and perhaps an additional MX-P50M amplifier (~40 W max.).
According to VOACAP the most promising bands for DX should be 15 m and 17 m during daytime and I will mainly use verticals (upper & outer, vertical dipoles) together with a 10 m mast.
Two of the above mentioned summits have been activated by Chris, ZD7CA/p, and I might be able to motivate our host Derek, ZD7CTO, to join me on some of my activations.
I will set up a preliminary long-time alert and add more detailed alerts later so that RBNHole will spot me whenever I am active.
Really chuffed to get you in the log this afternoon Andy! Many thanks for the QSO. I was particularly pleased as I’ve never made it outside of Europe on 10m before. Well worth sitting in a cold car on a gloomy afternoon to get the contact.
Thank you all!
Yesterday I was using just 10
W into a vertical dipole.
Conditions were excellent and I will probably use 10 m also for my next
activations.
I will update my alert as soon as I know when I will do my next activation.
From time to time my WSPR beacon is transmitting on 20 m … 10 m. It is connected to Derek‘s hexbeam. You can search on WSPRnet.org for ZD7MG.
